View Poll Results: How many quarts do you drain?
1-2 quarts
0%
2-3 Quarts
14.29%
3-4 Quarts
85.71%
Voters: 7. You may not vote on this poll
How much oil do you usually drain?
My xB2 has about 85k miles on it now and I change oil each time the light comes on. I usually buy a 5 quart jug at Walmart and after adding just over 4 quarts of oil, I pour the old oil back into the jug.
I just changed oil today and found that I drained about 3 quarts of oil after draining for about 15 minutes. My last oil change which was cold I only got about 2.5 quarts.
As long as I can remember it's been about 3 quarts each time.
How much are you guys draining???
My car has a rough idle once in a while, gets real shaky for a little bit, but I think I haven't noticed it since I seafoamed the car.
Anything in particular I should check? PCV valve?
Don't know how much drained into my pan, but the dip-stick previously indicated a normal level and when I refilled it took the advertised 4-1/2 qts (near enough), so I'll assume that's about how much came out -- the pan was pretty full (including the filter contents). It'd been 4200 miles since the previous change.
My suspicion is that it's burning some oil. I reckon there was only at most 1/4 quart of oil in the filter.
