View Poll Results: How many quarts do you drain?
1-2 quarts
0%
2-3 Quarts
14.29%
3-4 Quarts
85.71%
Voters: 7. You may not vote on this poll
How much oil do you usually drain?
Old Aug 28, 2010 | 10:03 PM
Malibu_Rapper's Avatar
Default How much oil do you usually drain?
My xB2 has about 85k miles on it now and I change oil each time the light comes on. I usually buy a 5 quart jug at Walmart and after adding just over 4 quarts of oil, I pour the old oil back into the jug.
I just changed oil today and found that I drained about 3 quarts of oil after draining for about 15 minutes. My last oil change which was cold I only got about 2.5 quarts.
As long as I can remember it's been about 3 quarts each time.
How much are you guys draining???
Old Aug 29, 2010 | 01:26 AM
renegade4x4's Avatar
should be around 3.5 -4. remember alittle stays in the filter as well. are you checking it to make sure its not burning any?
Old Aug 29, 2010 | 07:29 AM
My suspicion is that it's burning some oil. I reckon there was only at most 1/4 quart of oil in the filter.
My car has a rough idle once in a while, gets real shaky for a little bit, but I think I haven't noticed it since I seafoamed the car.
Anything in particular I should check? PCV valve?
Old Aug 29, 2010 | 10:32 PM
XD40tC's Avatar
All of it... lol jk
Usually when its time for an oil change my engine will be about a quart low. The dirtier it is the faster it burns off. Going on 58k miles.
Old Aug 30, 2010 | 12:30 AM
TrevorS's Avatar
Don't know how much drained into my pan, but the dip-stick previously indicated a normal level and when I refilled it took the advertised 4-1/2 qts (near enough), so I'll assume that's about how much came out -- the pan was pretty full (including the filter contents). It'd been 4200 miles since the previous change.
Old Aug 30, 2010 | 12:32 AM
ack154's Avatar
Originally Posted by XD40tC
All of it...
And here I thought I'd come here and be funny...
Someone beat me to it.
Old Aug 30, 2010 | 12:34 AM
TrevorS's Avatar
At that mileage, I'd think the PCV valve would be a good suspect if you're going through oil.
Old Aug 30, 2010 | 04:53 AM
XD40tC's Avatar
hehehe
Jvg2727
Scion xD Drivetrain & Power
Aug 24, 2015 04:40 AM
Forced4
Aug 21, 2015 09:22 PM
6885BLM8435
Aug 19, 2015 03:08 PM
Ways808
Aug 2, 2015 08:13 PM
michaelclld
Jul 16, 2015 04:32 AM
