cars or parts wanted
tC: WTB 05-07 Tail Light Harness
Old May 30, 2011 | 08:17 PM
egobuster1's Avatar
Default WTB 05-07 Tail Light Harness
looking to get 2 05-07 tail light harness's so i can purchase some anzo tail lights for my tC
Old May 30, 2011 | 09:38 PM
jeremydoc's Avatar
you can re-use your stock ones.
Old May 30, 2011 | 09:44 PM
egobuster1's Avatar
From the research I've been doing everyone says you need a 05-07 harness to use anzo tails and I have a 09
dropzone's Avatar
If he has an 08-10 tails he'll have issues with the reverse bulb not getting into the the housing. I've posted a pic showing the difference.
EDIT:Here ya go
http://m.flickr.com/#/photos/61201863@N07/5651660744/
Now look at your reverse bulb in the Anzo housing and tell me it'll look/work right using the shorter bulb plug of the '08-10.
Old May 30, 2011 | 09:46 PM
egobuster1's Avatar
Is that the only problem I would run into on this because I'd everything else works I might be able to like shave a tab off my harness to get the reverse bulb to fit
Old May 30, 2011 | 10:48 PM
egobuster1's Avatar
i dont get what the picture is showing here
Old May 31, 2011 | 12:06 AM
dropzone's Avatar
The reverse bulb setup on top is from the 08-10 harness(the short reverse bulb plug), the lower is from the 05-07(longer reverse bulb plug). I don't have any close up of the reverse bulb installed(also currently away from my car for a while to take any), but if you were to run the 08-10 the bulb will not be set in correctly to shine against the reflector. I just straight swapped in the 05-07 harness after comparing the two. You are welcome to try the 08-10 I you want to, js.
Old May 31, 2011 | 12:18 AM
egobuster1's Avatar
o alright so basically with the 08 harness the reverse wont be as bright as it should be but it will screw and lock into the slot just fine and besides that everything else will be fine
Old May 31, 2011 | 12:40 AM
dropzone's Avatar
I never tried to see if the '08 plugged in, so wouldn't be able to tell I it did clip in, sorry.
Old May 31, 2011 | 12:52 AM
egobuster1's Avatar
alright well thanks for you input, maybe someone else will chime in but from the stories and stuff im reading around on many different scion sites it seems that everything will hook up fine just the reverse bulb will be to short
Old May 31, 2011 | 05:20 AM
Eziekel's Avatar
yup, the two harnesses are different. only place you'll find one is either junkyard or the dealership. at the dealership i think it's $35 each side.
xBSciontist
Jun 18, 2019 03:06 PM
YooItsJay
Dec 2, 2015 08:13 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
TheTripleC
Jan 4, 2015 06:46 PM
mrbadass03
24
Apr 21, 2004 02:17 AM
