Hooking up factory bazooka tube to new head unit
Old Mar 21, 2005 | 05:39 AM
Rails's Avatar
Default Hooking up factory bazooka tube to new head unit
I just got myself an Alpine CDA 9833 and I was wondering how to hook up the stock bazooka tube I have to it?
THANKS!
Old Mar 21, 2005 | 11:29 AM
SCI_TC_GUY's Avatar
the plug on the factory tube should have power, ground, remote, and input(probably high level)...all you'll have to do is run it like a regular amp.....that is all I know because I haven't really messed with one of those......hopefully someone will be able to clarify on this matter....
Old Mar 22, 2005 | 04:04 PM
Rails's Avatar
..........bump..........
Old Mar 30, 2005 | 02:44 PM
Rails's Avatar
Can anyone else shed some light on this for me?? Going to be hooking up a new head unit next weekend I want to be sure I know what I'm doing.....
THANKS!
Old Mar 30, 2005 | 03:53 PM
ScionDad's Avatar
Yea, I just went thru this myself. The factory sub is not preamped out, it is tied into the speaker wires thru a separate adaptor that you should leave as is. I presume you got one of the toyota adaptors to hook into the factory harness...if not, get one (best buy has them). It will have two plugs (to match the factory plugs to the old HU) and bare wires on the other end.
On the package, it tells you which color wire on the adptor is what. On you new head unit, it's harness will also have descriptions for the bare wires. You will wire them together, then all you do is plug onto the factory harness and plug into you new HU.
Everything will match up.
I was concerned the sub would not sound good or not work at all. Wow, was I wrong. It sounds GREAT...much better that the stock HU ever did.
I was told (did not verify) that the factory amp to the factory sub has built in crossover to remove mids and highs to the sub.
Old Mar 30, 2005 | 04:56 PM
KevinxB's Avatar
So all you need is a regular Toyota wire harness for your new H/U and the Bazooka should work fine?
Old Mar 30, 2005 | 06:06 PM
ScionDad's Avatar
Thats what I did and it works fine. Went to Best Buy, bought the toyota 2 plug harness, wired it to the new HU harness and off it went. I thought for sure the sub would not work, but it sure does. Sounds much better.
It use to sound distorted when cranked up with the factory HU....not any more. Deep thumps....
sehall6h
Scion xD ICE & Interior
Feb 21, 2016 04:28 PM
MadSciontist_xB
May 10, 2015 06:28 PM
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
toyotaisme
Jan 10, 2015 10:24 PM
lunchbx05
Dec 11, 2014 06:13 PM
