Fuse Help
Old Apr 10, 2012 | 02:22 PM
anti_virus347's Avatar
Default Fuse Help
I just installed some LED tail lights for my 08. When you hit the brakes one tail light will just turn off. If you swap the plugs around they both turn on when you hot the breaks but the running lights wont come on. To me, it sounds like the fuse needs to get an upgrade as they are not getting enough power. Which fuse is for the tail lights tho? The manual and fuse box diagram was not helpful, nor was google.
Old Apr 10, 2012 | 03:11 PM
stocksciontc's Avatar
LEDs pull less power than standard bulbs thats why sometimes you have to run an inline resistor with the LEDs so it doesn't think the bulb is blown, so I don't think you would have to upgrade the fuse. I had to do the inline resistor mod with the turn signals in the headlights, and no changes to the fuse.
On my 06 scion tc, when I had LEDs on the tail lights, I didn't have that issue. No inline resistor needed, or a change in the fuse.
Just curious what kind of LEDs are you running?
Old Apr 10, 2012 | 03:25 PM
Oh man thats sucks. I was really hoping it was something simple. I called Toyota and the tech said he thinks something is grounding out.
Its these ones:
Old Apr 10, 2012 | 03:33 PM
Don't quote me on this...
I believe even if you were to change the fuse, it wouldn't provide more power to the LEDs/Bulbs than its already getting... its just to protect against excess current...
As far as I know you usually don't have to do extra modding to aftermarket tail lights... You might have gotten a bad set >.<
Old Apr 10, 2012 | 03:42 PM
Yes as stated above, its not the fuses. I wish I could change the title.
Its not a bad set, since that was the first thing i tried.
Old Apr 10, 2012 | 03:45 PM
I think if you edit your first post, you can change the title of the thread... Its been a while since i've been on this website >.<
Just to make sure its not a fuse problem... The tail lights you had on their previously... if you put them back on... do they still light up properly?
Old Apr 10, 2012 | 04:35 PM
I clicked on edit but it wouldnt let me change the title :/
Putting these in kind of sucked and I would rather not swap out to the old ones for a test. *sigh* this just sucks.
alexdrummerr30
Sep 8, 2018 12:18 PM
DannyBoy65
Sep 21, 2015 06:23 PM
spharr62
Sep 20, 2015 01:44 AM
OpTicaL
Sep 16, 2015 10:25 AM
SoCal_CJ
Scion tC 1G ICE & Interior
Jul 14, 2015 09:14 PM
