2 problems: Vacuum Leak and Noise. Seeking advice and input.
Old Apr 15, 2012 | 11:05 PM
asmith122's Avatar
Default 2 problems: Vacuum Leak and Noise. Seeking advice and input.
First, we've noticed a noise from the engine compartment. I'd describe it as "whirring with a hint of buzzing," like a cheap metal boxfan with old bearings or even like the engine noise from Mario Kart, but less electronic, of course.
It is related to engine RPM, not tire speed. Once we're going about 55 mph in 4th gear, the wind noise overwhelms it, but if I downshift to 3rd it is noticible again. This sound started maybe a month ago, I think.
Second, last week we had the three lights come on (Check Engine, VSC, Trac Off). The scanner said P0442 (Evaporative emission system, small leak or no flow condition).
A local shop said it was just a cap and filler neck problem, and is waiting on an estimate to replace the filler neck. My first question is: how much should replacing the filler neck cost?
My second question is: Could a vacuum leak up front cause the type of noise we're hearing?
This xB is a 2005 with about 140,000 miles. My wife is driving it over 1000 miles a week now for work, so we want to be preemptive if a fuel pump is about to die or something.
Thanks everyone. this is my first time posting, but I've gotten a ton of good info off this board over the years (including info on repairing my gate latch).
Old Apr 19, 2012 | 12:12 AM
blown_xa's Avatar
There is only one vacume line on the car, right behind the throttle body. It feeds the evap solenoid, which vents the gas tank. Visually check that line, it may be the problem.
Old Dec 30, 2014 | 09:00 PM
Xavior's Avatar
I have the same problem, the mechanic quotes me $299 for filler neck replacement (part + labor), how did you fix your problem ? Was it the filler neck?
Hydryman
Feb 23, 2016 03:35 PM
SCGBox
Sep 23, 2015 03:29 PM
JymmyTheSaint
Aug 26, 2015 03:44 PM
Jvg2727
Scion xD Drivetrain & Power
Aug 24, 2015 04:40 AM
wejarrell
10
Aug 5, 2015 09:19 PM
