auto off headlights?
Old May 5, 2005 | 02:26 AM
kgoodbuddy's Avatar
Default auto off headlights?
I keep hearing conflicting reports about the xB headlights----will they turn off automatically? If not, is there a way to make them automatic? My dealer had NO idea.
Old May 5, 2005 | 02:32 AM
Max's Avatar
Max
They do not turn off automatically. There is a way to make them turn off, but not a feasible one.
Old May 5, 2005 | 02:48 AM
crayonBOX's Avatar
nope, that's a tC feature
Old May 5, 2005 | 03:04 AM
kgoodbuddy's Avatar
You guys are speedy! I guess I'll just have to get used to turning them off myself---although my biggest worry probably will be remembering to turn them ON.
Old May 5, 2005 | 03:54 AM
SciFly's Avatar
can you tell more about why? how unfeasible is it? (I'd still like to do this if its not too hairy)
thanks!
Old May 5, 2005 | 06:22 AM
Evil_Xb's Avatar
There is an aftermarket system you can install to automatically turn your headlights on at dusk, and then it will turn them off after you turn the ignition off with a short delay. Its pretty much the same as a factory auto on and off system.
David.
Old May 5, 2005 | 06:50 AM
djct_watt's Avatar
Team Sushi
You could also wire your headlights to only get power when the key is in. . . but that can be a bad idea too.
Old May 5, 2005 | 08:49 AM
SciFly's Avatar
what is the downside of the simple, old way: a headlight relay switch interupting the headlight current whenever the ignition is -off-.
seems -simple to do- but I have not studied Scion electrics nor any modern car electrics. I -did- do some pretty nifty and unique electricals to my old henry ford coupe: keyless ignition combination lock. Relay to run the headlights either in parallel on 12v, or in -series- for 6V guard-glo (daytime running mit der low current drain to ease the puny generator's work.
so.. can't such simple things as relays be put into a scion headlight circuit?
(me needs to get thescion shop manuals on disk!)
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
stenger
Jul 15, 2015 01:03 AM
SoCal_CJ
Scion tC 1G ICE & Interior
Jul 14, 2015 09:14 PM
nightwitch
Jul 14, 2015 01:58 AM
