How to Remove Center Console with Auto Trans?
Old Jun 3, 2005 | 11:36 AM
matt_a's Avatar
Default How to Remove Center Console with Auto Trans?
I want to do the cup holder illumination in my wife's new xB. I did it in my xA, but that was with Manual Trans and all I had to do was unscrew the shift **** and lift the console up over it
(after taking the screw out of the rear cup holder and popping the front tabs loose).
How do you do it with an Auto Trans? Does that trim ring around the base of the shifter just pop off?
____
Old Jun 3, 2005 | 01:07 PM
matt_a's Avatar
Anyone? Anyone?
Old Jun 3, 2005 | 01:17 PM
tbone587's Avatar
Default here
Its really easy. Basically look at the single cup holder near the rear of the center console piece. There is a piece of felt in there that you need to take out. Then, take out the screw and then pull up on the side of each of the cup holders up front. Once you have the center console piece disconnected you just maneuver it over the shifter and your done.
Old Jun 3, 2005 | 01:23 PM
matt_a's Avatar
Yeah, I know about the screw under the felt in the rear cupholder, and about the two clips up front. I just wasn't sure about the area around the auto shifter. Are you saying it just lifts up....nothing to pop free?
Old Jun 3, 2005 | 03:45 PM
tbone587's Avatar
Default yeah.
yeah, once the screw is out and the two clips are released up front, it will lifht right up, you just kinda have to turn the piece to the side after you lift it up to get it over the shifter ****.
Old Jun 3, 2005 | 03:46 PM
matt_a's Avatar
Awesome. Thanks dude!
Old Jun 3, 2005 | 04:04 PM
peabe's Avatar
wait...the auto shifter **** comes right off? no need to unscrew anything?
Old Jun 3, 2005 | 04:15 PM
Sparks_Scion_TRD_Parts's Avatar
Default Re: How to remove center console with auto trans?
Originally Posted by matt_a
I want to do the cupholder illumination in my wife's new xB. I did it in my xA, but that was with manula trans and all I had to do was unscrew the shift **** and lift the console up over it (after taking the screw out of the rear cupholder and popping the front tabs loose). How do you do it with an auto trans? Does that trim ring around the base of the shifter just pop off?
Hi Matt,
If you send me your email address, I'll send you a file with the install instructions from Toyota. Or, if you can wait a little while, we're putting it up on our site now. It'll be in the upper right hand corner of the page in just a bit.
Old Jun 3, 2005 | 04:17 PM
Here you go, it's in B.
http://www.trdsparks.com/displaypart...4&parts_id=382
Ken
Old Jun 3, 2005 | 05:17 PM
matt_a's Avatar
That's perfect! Thanks!
Old Jun 3, 2005 | 05:37 PM
Default You're welcome
Glad to help.
Ken
Old Jun 3, 2005 | 06:19 PM
TheScionicMan's Avatar
Don't forget to disconnect the wire for the shift indicator light.
Old Mar 30, 2017 | 03:15 PM
Xdboombox's Avatar
Default Thanks dude
lifted up that piece of felt and I felt like I hit the lotto. Thanks a million dude
hybrid86
Nov 9, 2009 06:19 PM
aggiecasi
Oct 13, 2008 10:41 PM
soisauce757
Scion tC 1G ICE & Interior
9
Sep 15, 2008 11:37 PM
phoenixtc
13
Nov 29, 2005 07:47 PM
dischinezeboi
Jul 14, 2005 10:12 PM
