Amp problem
Old Jun 14, 2005 | 03:36 AM
scionxboombox's Avatar
Default Amp problem
When ever I turn the music loud the amp turns off, does anybody have any idea what's going on?
Old Jun 14, 2005 | 03:41 AM
VIP_tC's Avatar
Check your ground connection and make sure everything is very secure. Chances are you have your gains turned up too high and are clipping the amp and pushing it too hard. It is probably going into protect mode... what amp do you have and what speakers are you runnig? it may be time to buy a bigger amp
Old Jun 14, 2005 | 03:44 AM
650.4 kicker and pioneer components (yellow series)
Old Jun 14, 2005 | 04:25 AM
mike51392's Avatar
my amp use to do that when it use to over heat but check all your connections and make sure there fasened down right - also check the adjustments on your amp
Old Jun 14, 2005 | 04:29 AM
I'll check the connections. thanks for your help.
Old Jun 14, 2005 | 12:07 PM
neckbonenick's Avatar
2 reasons come to mind.
1. you might have your subwoofer, especially if it's a dual coil wired wrong. So the ohms are too low and it turn the amp off.
2. Your amp is simply overheating from the load.
Old Jun 14, 2005 | 05:23 PM
Reign_Man's Avatar
do you have a cap? i had a cap in my last system and it wasnt grounded right and it made my whole system loopy...
Xaphoon
Scion tC 2G ICE & Interior
Apr 22, 2015 02:36 PM
stillcole
Apr 6, 2015 03:42 PM
TheSilencerTC
Feb 24, 2015 04:56 PM
missing_image
Feb 7, 2015 07:18 PM
