s/c tC and Cobalt SS underrated?
Old Oct 25, 2005 | 05:25 PM
Scion-ce's Avatar
Default s/c tC and Cobalt SS underrated?
I have the s/c tC and it dynoed at 192whp and 172wtq
this is equal to about 225hp and 200 ft/lbs
The Cobalt SS was rated at 205hp and about 200 ft/lbs.
I read another forum and apparenly the stock Cobalt SS was vastly undserrated
It dynoed at 217whp and 185 wtq
this is about 255hp and 217 ft/lbs
Are these Cobalt SS dyno results accurate?
Old Oct 25, 2005 | 05:28 PM
THE_DON's Avatar
I've heard the SRT-4 is WAY underrated as well...
As far as the TRD supercharged tC, I don't think Toyota ever stated an actual HP number, so it's hard to say.
-THE DON
Old Oct 25, 2005 | 05:33 PM
Mizle's Avatar
thats a quick little cobalt if those numbers are correct.
Old Oct 25, 2005 | 05:46 PM
Scion-ce's Avatar
Damn, if those Cobalt dyno numbers are right, I just spent 3000 + install and am still slower than a riced out cavalier???
Old Oct 25, 2005 | 05:50 PM
ScionDad's Avatar
Rest assured in a year, that Cobalt will be a bucket of junk. From rattles to falling apart. Resale will also be a huge difference. You will be driving a solid car for many years to come.
Old Oct 25, 2005 | 05:51 PM
killerxromances's Avatar
The orginal statement from TRD was the supercharger will produce 215-225hp. Right before its release, to my understanding, they played it down a little and said 200hp. I'm not really sure which one is correct, can you provide a dyno sheet run to prove you have 192whp? I'm not saying are lying, infact you are probably not. But too many people here post numbers that we later find out were false.. Its a good idea anyway, more bragging rights for you!
As far as being slower, well you should have bought the zpi turbo instead. Jk, but seriously, its TRD. You had to expect that.
Cya
Old Oct 25, 2005 | 05:59 PM
FLINT's Avatar
the cobalt looks uuuuugly bruh. dont worry about it. i know u still pullin chics, lol.
Old Oct 25, 2005 | 06:04 PM
Scion-ce's Avatar
Cya
Well the numbers they posted were obviously wrong because the supercharger wasn't out yet. tCarlo was the first to get it installed. I was the second. We both live in Maryland in the same county. He took his car to the dyno right after he got it from the dealership.
Have you not seen the thread in power hungry?
Its called "supercharger update, pics,vids, dynos"
somethin like that. You can't miss it. All he has done to his car is the trd exhasut that we all know provides no power. Those number were on a pretty much stock tC.
as a matter of fact here is the link https://www.scionlife.com/forums/viewtopic.php?t=87809
go to page 3 for a pic of the dyno sheet.
Old Oct 25, 2005 | 06:26 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
cobalt ss == pile of poo
test drove one, was never happier to get out of a vehicle, ever!!
saturn ion is almost as bad!!!
and yes, 192whp is wut the s/c put down on stock motor.
Old Oct 25, 2005 | 06:35 PM
metalranger33's Avatar
the cobalt only pulls mid to high 14s (saw it at the track) and my tc pulls low to mid 15s, i cant see why the S/c Tc would lose...
Old Oct 25, 2005 | 06:40 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
put an inexperienced driver behind the wheel of either, and theres ur answer
Old Oct 25, 2005 | 07:07 PM
Scion-ce's Avatar
Even still 255 at the crank is still pretty impressive.
With header, s-pipe back exhaust and umnitza intake, should match or exceeed the Slowbalt
Old Oct 25, 2005 | 07:14 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
so enough bout the SS, you should be settin ur sights on racing something that is impressive
Old Oct 25, 2005 | 07:16 PM
TheQuietThings's Avatar
i dont know why everyone is hating the cobalt.
The car is refined and its a very fun car to drive, and its faster than the tC.
its not nearly as refined as the tC, but no american made economy car is nearly as refined as any japanese car
Old Oct 25, 2005 | 07:21 PM
Garage1217's Avatar
Here are some fun facts for you kiddies.
The cobalt has issues with the ecm and is moody. They run good, then they do not then the next day they do.
Also it uses an eaton supercharger. While they work well for oem I have personally found them to be quite problematic especially running more psi than a stock 7-8 psi setup. How do I know this? I have receipts for 3 new eaton m62 superchargers that I could only get to last for 30K miles each before they started sounding like a spoon in a blender and then seizing totally. That was at 14 psi. At the stock boost level they usually last 60-70K miles tops before a rebuild is required. They are a good blower and when setup properly "most oem's do not even come close to getting it right" they provide instant boost that accounts for wicked throttle responce. Makes cars properly equipped VERY fun to drive.
The votech is more suited to higher revving engines and engines with a focus on the mid to top end of the powerband. TRD made a very wise choice with this blower.
Also the eaton supercharger is very easily head soaked for it's massive aluminum body and when a vehicle equiped with an eaton heats up underhood then performance usually drop off by a noticable amount.
Last bitc* of the eaton is the way 99% of the oem sets them up, they are very very difficult to intercool because they are usually attached directly to the intake plenum. You can use water injection on them like I used to but it was a total pain in the **** filling up the tank all the time and performance was still somewhat inconsistant.
Us trd sc guys are very lucky trd chose the vortech. They are easy to intercool and the sc has MASSIVE potential to turn your tc into a 300+whp rocket.
BlkSandPrlTurbotC's Avatar
we're hating on the Cobalt SS (2.0/2.4L) not the basic Cobalt.
Reguardless, it's a freakin boat! I'm content with my tC
Old Oct 25, 2005 | 07:22 PM
i know i was talking about the SS
Old Oct 25, 2005 | 07:26 PM
ah, sorry my bad....saw cobalt lol
reguardless, it's a ____ car! it's a Heavy Heap of Pile of SS Poo!
sIcKsCiOnS
DelMarVa
Scion Tuners
i think we are hating, well becuz....its a chevy
Old Oct 25, 2005 | 07:27 PM
do you hate on corvettes because they are made by chevy?
