Best amp for 2 - 12" Type R
Old Jan 30, 2006 | 05:59 AM
cfire39275's Avatar
Default Best amp for 2 - 12" Type R
Right now i am running 2 rockford 201S (600Max) amps, connected to 2 rockford .5 farad caps. They hit fairly hard, but i know that they could bump a whole lot more. What kinda amp would you recommend to push this setup?
Some quick Specs.
12" Alpine Type R
Full Specifications
General Features: Dual Voice-Coil
Sensitivity: 87 dB
Speaker Configuration: Single Speaker
Cone Material: Kevlar Reinforced Pulp
Cone Style: Cone
Diameter: 12 in
Nominal Impedance: 4 ohm(s)
Nominal Input Power Rating: 500 W
RMS Power Output: 500 W
Peak Power Output: 1500 W
Overall Max Frequency Response: 500 Hz
Overall Min Frequency Response: 24 Hz
Maximum Input Power Rating: 1500 W
Thanks in advance!
Old Jan 30, 2006 | 12:50 PM
SCI_TC_GUY's Avatar
Looks like you need a mono class D 1000x1 @ 1ohm amp... Those subs are 500RMS each and depending on how you have them wired, you might be getting 200 rms each...
What kind of budget are you looking at for a single amp??
Hifonics is a good inexpensive brand....
Old Jan 30, 2006 | 04:00 PM
cfire39275's Avatar
Well i want to keep it kinda cheap, but at the same time, I want to be able to pop my trunk and have mouths drop, not have them laugh at me. Im gonna put both amps up for sale, and put that money towards a new one.
I was thinking about this Alpine amp
http://www.bestbuy.com/site/olspage....=1099388650996
Open for any and all suggestions.
Thanks
Old Jan 30, 2006 | 04:07 PM
SCI_TC_GUY's Avatar
This amp will push those speakers more than that alpine and it's cheaper.... with subs, you won't even be able to tell any difference except they'll get louder....
and it's only $220
http://www.woofersetc.com/index.cfm?...roduct_ID=3374
Old Jan 30, 2006 | 04:22 PM
cfire39275's Avatar
Quite an amp you picked out there. My friend has a 'Son of Boltar' amp. The only reason I picked the alpine was to match the system and I get a discount at BB.
If anyone else has some suggestions I will gladly take them. But this looks like a great amp to me.
Thanks for the info,
T.J.
Old Jan 30, 2006 | 04:36 PM
SCI_TC_GUY's Avatar
Red flag.... this is in the description for your alpine amp...
"400W RMS (continuous) x 1 @ 2 ohms, 12V, 20-200Hz, 0.3% THD
250W RMS (continuous) x 1 @ 4 ohms, 12V, 20-200Hz, 0.3% THD
600W RMS (continuous) x 1 @ 2 ohms, 14.4V, 20-200Hz, 0.3% THD "
If you have 2 dual 4ohm subs, you need an amp that puts out 600-1000 watts RMS x1 @ 1ohm.... that amp will only push 400x1 @ 2ohm mono.... the 600x1 is at 14.4v and isn't accurate...
Old Jan 30, 2006 | 04:54 PM
cfire39275's Avatar
First of all, i just want to thank you for being extremely helpful. Second, I just wanna make sure Im gonna be looking for the right thing when Im looking for an amp. I am looking for power rated at 1 ohm. For example...
RMS Power Rating: 1600 watts x 1 chan. @ 1 Ohm
(Brutus Amp) http://cgi.ebay.com/ws/eBayISAPI.dll...category=18797
So if i were to pick this amp because of power, this would be just what I am looking ?
Old Jan 30, 2006 | 04:58 PM
SCI_TC_GUY's Avatar
That's correct.... you're looking for Xwatts x1channel @ 1ohm
I probably wouldn't go over 1000 watts on those subs though..
Old Jan 30, 2006 | 05:02 PM
cfire39275's Avatar
Even if that 1000Watts is split between the subs? Ahh, nevermind (500Watts RMS X 2). Well anyway i got the Bestbuy Protection plan, so i can blow them all I want for the next 3 and a half years and get them replaced for free. And i guess i can always turn the amp down.
Old Jan 30, 2006 | 05:44 PM
SCI_TC_GUY's Avatar
When you say "turn the amp down", do you mean the gain?? if so, you don't want to do that because it will cause clipping of the signal going into the amp and possibly blow your subs... If you're talking about at the bass ****, yeah that'll work.... as long as you're not playing bass test CD's too hard you should be fine..
Old Jan 31, 2006 | 04:07 PM
cfire39275's Avatar
One last question, im sure ill have to dig my book out for this one...
How would i wire these subs for a 1ohm load??
Correct me if i am wrong, but if i wire it in a series, i would get a 2 ohm load, and if i wire it paralled i would get a 8 ohm load (Since they are 4 ohm subs).
So, shouldnt i look for an amp with rms rated at 2ohms instead of 1ohm?
Old Jan 31, 2006 | 04:21 PM
SCI_TC_GUY's Avatar
Each sub is a DUAL voice coil 4 ohm.... meaning each sub has 2 4ohm VC's.... wire each sub independantly in parallel to make each sub 2 ohm total... then parallel the 2 subs together to get 1ohm.... like this
Old Jan 31, 2006 | 04:55 PM
cfire39275's Avatar
Wow, dont i fell like an idoit. That makes sense.
I just want to thank you again for all of your help. When i get it set up, ill make sure to post some pics.
Thanks again,
T.J.
Old Jan 31, 2006 | 05:00 PM
SCI_TC_GUY's Avatar
any time you have a Q, just shoot me a PM... no problem at all..
yupinmytC
22
Jul 27, 2024 07:08 PM
rvascion
Nov 12, 2020 03:23 AM
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
DannyBoy65
Sep 21, 2015 06:23 PM
