For creatine users...
Old Feb 16, 2006 | 03:05 AM
DJ_Seksies's Avatar
Default For creatine users...
I was wondering if results would show if I use it and dont lift weights but I just do regular excercises (push ups, sit ups etc...). The reason for this is that my dads bench press and all of his weight lifting systems are not set up yet and I will have to wait about spring break to help him set it up. Thanks in advance.[/u]
Old Feb 16, 2006 | 02:18 PM
HeathenBrewing's Avatar
Creatine will help, but you really should be hitting the iron to really see what it will do for your body.
Creatine provides your muscles with more short term energy - but that is wasted if you do not exercise them. If you take creatine you should push yourself even harder in the gym. The idea is with more energy you should be able to workout harder. A harder workout leads to increased muscle mass.
I would like to emphasize that creatine will not work if you are not properly hydrated! It relies heavily on this, so you must drink tons of water, if you want optimal results from it. Super hydrating your body will also improve your weight room pumps tremendously!
It is NOT a steriod and does NOT affect hormone levels. It is very safe with no side effects.
Old Feb 16, 2006 | 02:21 PM
Stu_Gotti's Avatar
You def will blow up if you take it in conjunction with a heavy workout routine!
Old Feb 16, 2006 | 02:31 PM
matt_a's Avatar
^Exactly. Well said. Creatine is fuel, but YOU have to do the work. I would also recommend a high-quality whey protien shake for after the workout. It helps the muscles to rebuild and repair.
Old Feb 16, 2006 | 03:49 PM
Stu_Gotti's Avatar
All good advice.. another good thing to eat is a peanut butter and bannana samich.. lots of protien and potassium for those sore muscles and bones
Old Feb 16, 2006 | 05:40 PM
DJ_Seksies's Avatar
Thanks for all the advice, so I guess I will wait till spring to set up the equipment first then.
Old Feb 16, 2006 | 08:11 PM
TCgetonmylevel's Avatar
yeah if you take protein afterwards stack it with amino acids pills they help your body absorb the expensive protein instead of poopin it all out.
Old Feb 18, 2006 | 06:01 AM
SinIsSick's Avatar
^^^I concur with this man. I am on a nitrous oxide product, protein, and ammino acids and I have toned up and put muscle on in a short period of time.
Old Feb 19, 2006 | 02:44 PM
Rocket's Avatar
There are no short cuts to building muscle!
Nothingness
Mar 22, 2009 06:35 AM
NYCmainah
21
Aug 17, 2007 12:50 AM
NYCmainah
Aug 10, 2007 08:58 AM
NYCmainah
Aug 6, 2007 12:53 AM
djct_watt
May 13, 2007 06:38 AM
