Can an amp go behind the rear panels...Answer Inside....
Old Mar 27, 2006 | 12:56 AM
mandos's Avatar
Default Can an amp go behind the rear panels...Answer Inside....
That's a big yes
Stock Rear Panel:
Modified Rear Panel:
Mounted amp:
Please excuse the wire mess...they were cut to length to reach the back of the hatch...need to recut them.
Old Mar 27, 2006 | 01:22 AM
fujitech43's Avatar
nice job but how did you attach the wood to the side panel?
Old Mar 27, 2006 | 01:57 AM
mandos's Avatar
2 4" bolts, 1 3" bolt...well...it was a 4"er but I cut the end off
There's some in progress shots, but my normal host is down and SL only gives 300K so I'm at my limit.
Old Mar 27, 2006 | 04:20 AM
eujin's Avatar
thats nice and stealthy, good work man.
Old Mar 27, 2006 | 02:19 PM
SCI_TC_GUY's Avatar
only you man.... only you....
Old Mar 27, 2006 | 02:49 PM
CXT's Avatar
CXT
Mandos is Loco
Hey can you remind Scott to measure your spare tire well to see if can build me a box for the 190v I got coming?
Old Mar 27, 2006 | 02:59 PM
mandos's Avatar
Yeah yeah...he'll be measuring when I move my back seat out of the hatch
Before:
After, take note of the new hole drilled on the bottom right of the speaker mount:
Mounting board:
Didn't feel like cutting any other metal yesterday...so I remade the MDF baffle a few times before getting the right size
Old Mar 27, 2006 | 03:02 PM
bbcrud's Avatar
Scionetics
Post your car in the Car Show on Scionetics. Up to 25 pics and easily linked to. My car show is in my signature below.
Nice job. Can't wait to see it finished!
Old Mar 27, 2006 | 03:05 PM
THansenite's Avatar
I saw this car yesterday and it is insane. He pulled the panel off to show everyone the hidden amp so it does fit behind the rear panel. He had the skeleton in the back for his million speakers as well. I can't wait to see this car finished.
Old Mar 27, 2006 | 03:16 PM
bbcrud's Avatar
Scionetics
Gotta love people willing to put that kind of effort into their car.
Old Mar 27, 2006 | 04:27 PM
PghtC's Avatar
It worries me that the nuts will come loose and it will rattle. That, and if you ever want to adjust the level or filters on the amp, you have to pop off the wall. But I must say, bravo on making it work.
Old Mar 27, 2006 | 04:34 PM
mandos's Avatar
Lock nuts on everything.
PLUS...I made the 3 holes ever so slightly off center so it's also slightly torqued in there. I punched it a few times and it wouldn't budge.
Yes...it's scary punching a big sheet of wood at the outside of your car ;)
As far as settings, Eclipse 8443. 8V out, if I touch the gain on the amp leads to clipping. Everything else I handle right out of the HU. I honestly wish our amps had no x-overs/bass boost on them, just not a fan of 'em.
Old Mar 27, 2006 | 07:29 PM
bbcrud's Avatar
Scionetics
Excellent choice on the HU, that's what I chose and it does very well for me!
Old Mar 27, 2006 | 07:44 PM
PghtC's Avatar
fair enough...
Old Mar 28, 2006 | 09:21 AM
tweetertc's Avatar
the only thing i dont like about it..
what if the amp ever goes bad... or you feel that you want to adjust... or for some reason you want to get at the amp...
sounds like way too much of a pain in the **** to me.... looks cool... just something i more than likely wouldnt do...
Old Mar 28, 2006 | 11:46 AM
SCI_TC_GUY's Avatar
^^ when your entire trunk is going to be engulfed with 32 6.5" speakers, you've gotta find someplace innovative to hide them babies...
Old Mar 28, 2006 | 11:48 AM
PghtC's Avatar
^^Good Point.
Old Mar 28, 2006 | 02:17 PM
mandos's Avatar
From full interior to gutted for me, less than an hour. To get just that panel off, maybe 10 minutes.
As mentioned previously, I NEVER use amp adjustments. Plus...when you've got a midbass on one channel and a component set on the other channel, can't really have common x-overs.
Really no reason ever to touch the amp.
Old Mar 28, 2006 | 02:43 PM
krdshrk's Avatar
Interesting. How about heat issues? If you're putting the panel back on wouldn't there be little to no ventilation?
Old Mar 28, 2006 | 02:52 PM
mandos's Avatar
That area is joined to the rear of the car for ventilation, where the recirculate vents are.
Plus, air can get in through the speaker hole...once the back is sealed up, air will be forced across the amp
