Can an amp go behind the rear panels...Answer Inside....
Old Apr 16, 2007 | 03:49 PM
  #61
rhino74s's Avatar
Cool, just found this today! I'm gonna mount my Nine4 there.
Also, anyone have pics or can tell me where to mount crossovers in the doors?
Old Apr 16, 2007 | 04:18 PM
  #62
zm_br's Avatar
I just mounted my crossovers for my door speakers to my kick panels.
Old Apr 16, 2007 | 07:36 PM
  #63
exige's Avatar
you dont have to mount em on your kickpanels....liable to get...well..kicked...if you push them up behind the glovebox, you can hold em up there with some zip ties. thats what i did with mine. or you can try drilling them to the door or something....but i think its plenty safe enough tucked up behind the dash. zm_br, im puttin the same EQ in, do you normally adjust your volume from the head unit....i thought it said in the clarion manual to always adjust the volume with the EQ's ****....?
Old Apr 16, 2007 | 07:43 PM
  #64
zm_br's Avatar
I adjust from the head unit since it's on the steering wheel. I have a Massive EQ in my other car, and it seems like the Volume **** is very touchy, so I don't bother with it. But, that could just be the brand. Really, I don't think it makes a huge difference. Adjusting by either HU or EQ will give you close to the same results.
Oh, and I mounted my crossovers on the kick panel since i already had my EQ mounted down low.
Old Apr 29, 2007 | 04:59 PM
  #65
Yanki01's Avatar
plan on doing this pretty soon, anyone have anymore pics, post em up!
Old Apr 30, 2007 | 12:59 PM
  #66
zm_br's Avatar
not much different from the pics of mandos' car.
Old Apr 30, 2007 | 01:54 PM
  #67
IAmTheProdigy's Avatar
Any measurements for the board and were you able to use any pre-existing holes beneath the panel for mounting?
Old Apr 30, 2007 | 02:00 PM
  #68
zm_br's Avatar
i just guesstimated about an inch and a half around each side of the amp, and i drilled new holes for the bolts. i didn't care really how the bolts or wood looked since it's going to be behind the panel and hidden from view.
Old Apr 30, 2007 | 06:21 PM
  #69
iScion's Avatar
Can I hide there 25 inch long amp?
Old Apr 30, 2007 | 09:51 PM
  #70
mandos's Avatar
I had trouble w/ 15"...I doubt 25" is going to fit.
Old Apr 30, 2007 | 09:54 PM
  #71
mandos's Avatar
Also, Matt lies, mine is cleaner.
Old Apr 30, 2007 | 10:16 PM
  #72
zm_br's Avatar
cleaner at the moment, yes. mounting direction is similar. whenever i put the panels back on, it will be all organized.
Old May 9, 2007 | 02:41 PM
  #73
rhino74s's Avatar
So no one is having heat issues with this install?
I installed my Nine4 there but after about 20 minutes of play, the heat protection kicks in. I am still using rear speakers and it has been hot as hell here lately but I really like this location. I mounted a couple fans yesterday, so I'll see if that helps. Could having the rear speakers still in block enough air to make it overheat?
Old May 9, 2007 | 02:53 PM
  #74
mandos's Avatar
My Nine.2's been there for over a year, my Nine.1 for about 5 months. Never an issue with either and it was 100+ for a good week here last year.
Old May 9, 2007 | 02:58 PM
  #75
rhino74s's Avatar
Problem solved:
I just found out that the Nine4 is not 1ohm stable. I was running the 9kv D2 in parallel. Seriously overworking the amp. Rewired it to series at 4ohm so should have no problems now. At least I know the heat protection circuit works and I have only had it installed for a couple days and haven't pushed it hard.
Xaphoon
Scion tC 2G ICE & Interior
Apr 22, 2015 02:36 PM
stillcole
Apr 6, 2015 03:42 PM
TheSilencerTC
Feb 24, 2015 04:56 PM
cwong1001
Dec 3, 2014 03:30 AM
