Starting problem
Old May 9, 2006 | 07:19 PM
TC-N-Philly's Avatar
Default Starting problem
The problem is only happening when the vehicle is cold. Morning, mostly after sitting all night. I turn the ignition and the car starts to chug like normal. When it is about to turn over it fumbles a lot whcih means I have to stay on the ignition longer. Fuel pump maybe? Thoughts before I take it to the stealership
The car has 38K on it already just FYI.
Old May 9, 2006 | 07:21 PM
TheQuietThings's Avatar
how new is your car? it happens to pretty much all tC's within the first few months of ownership. Its also possible that you have some bad gas, or a worn down battery already.
Old May 9, 2006 | 08:00 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
been posted alot here lately
i HAD the same issue, but just went ahead and performed fuel induction service
haven't had a problem since, been about a week
another owner on here switched from 93 to 87 octane and his problem has been gone since
check the charge on your battery, then take it to the "stealership" as you call it
see if they can find something you can't
Old May 9, 2006 | 08:36 PM
xnevergiveinx's Avatar
yeah, it happened to me twice in the first month of ownership. one time it was super cold outside...the other time it was kind of hot and i barely had any gas
never happened since then and i have 14k
Old May 9, 2006 | 08:40 PM
fro's Avatar
fro
happened to me first thing in the morning yesterday. I have about 33K miles on my car, I just figured it had something to do with the chilly morning and the damp weather from rain sunday night.
Old May 9, 2006 | 09:04 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
Fro,
it only happened to you that one time??
Old May 9, 2006 | 09:38 PM
Ranthese's Avatar
only happends when it's cold and starting up for the first time
Old May 9, 2006 | 09:45 PM
scoobyroo2002's Avatar
This has happened to me as well. I remember one time i started it and i swear it sounded like there was rocks in there or something. It was just this big CLUNK! i was like WTF then i turned it off and tried it again...started fine, this was about 2 months ago...hasnt happened since.
Old May 9, 2006 | 09:52 PM
2LoTc's Avatar
every so often recently i've been having the coughing/fumbling during start up. Sounds like its not gonna turn over and just stall out for like one quick second, then starts up and runs normal. hasn't been on COld days (50-70 degrees)
Old May 10, 2006 | 03:38 AM
I haven't been on in a while but what is this fuel induction service?And what is the cost? This has been happening to me just about every morning. A normal day here is like 65-70. At night it dips to the 50's. I wouldn't say this is due to cold starts. The car is an 05' with 38K on it already to the guy that asked. I still don't know what the problem is?
Old May 10, 2006 | 03:52 AM
just spray some seafoam deepcreep in the intake and let it soak for a little bit. i really doubt the dealership will do much more than this
Old May 10, 2006 | 02:05 PM
natodog's Avatar
sounds maybe like bad gas or vapor lock
Old May 10, 2006 | 08:07 PM
2LoTc's Avatar
happened again this morning-not cold at all. ONly car was sitting all nite. REally chugs a bit before starting. Didn't happen any other times i started the car later in the day.
Fuel or ignition system maybe?
Old May 11, 2006 | 03:41 PM
I'm taking mine in next week. It is either the battery or some fuel problem. I just filled a new tank today so I'll give it a week. After the first morning start, it starts fine the rest of the day.
Old May 11, 2006 | 04:30 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
i switched over to 87 gas tuesday, and it starts/runs just a tad better even after the FI service
Old May 11, 2006 | 06:32 PM
chipmOnk's Avatar
Same thing happened to me except it was a hot evening around 5pm.
Old May 14, 2006 | 01:15 AM
2LoTc's Avatar
so yeah, it just happens every time i start up after the car's been sitting for an extended period (over nite). Just a real labored ignition feel. Like its about to start, then kindof stalls for a millisecond, then starts up kinda sluggishly.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
BV19869
Dec 11, 2014 06:05 PM
