side airbags?
Old May 22, 2006 | 02:23 AM
BlkTC's Avatar
Default side airbags?
i have side rear airbags and a pillar bar waiting to be put in. I want to know if anyone ever took them out before and if they did, how hard is it. im not planning on getting into an accident nor am i keeping people in the back seat.. So if you know how to take out an airbag, please let me know! For the rear side panel FYI.
Old May 22, 2006 | 02:43 PM
THansenite's Avatar
Who DOES plan on getting into an accident? I wouldn't mess with my airbags. The benefits far outweigh the negatives if something does happen while in your car.
Old May 22, 2006 | 02:56 PM
ThePerchik's Avatar
I was trying to take the a-pillar off this weekend to ge to the dashboard screws. Let me tell you, with SRS i have no clue how to do it. It was mucho hard. I could only pull the top off, about an inch. And that was it, it wouldnt give.
Old May 23, 2006 | 10:10 PM
BlkTC's Avatar
aww crap.. uhmm.. The rear ones wont help that much if i don't have anyone in the back seat though right? So... yeah..
Old May 23, 2006 | 10:21 PM
SquallLHeart's Avatar
uhh.. rear.. airbags?
Old May 24, 2006 | 12:06 AM
Thermalzeal's Avatar
Yeah you gotta realize, inorder for the A pillar to not explode to pieces when the airbag deploys its CRAZILY Stuck to the frame.
Old May 24, 2006 | 01:33 AM
uhh... the airbag is a curtain that comes down where your window is...
the a-pillar doesn't do anything..
Old May 24, 2006 | 01:39 AM
tcBlue's Avatar
I think the curtain airbig is in the a-pillar, right?
Old May 24, 2006 | 02:27 AM
hmm... gently pry a little part the section above your window where the handle is. peek inside.
ta da... curtain airbag.
whatever's in the a-pillar is probably electronics/sensors/ other crap that makes it deploy.
Old May 24, 2006 | 02:37 AM
tcBlue's Avatar
So, you are saying the a-pillar with the sign "SRS airbig" does not actually contain the airbag? mummm...
Old May 24, 2006 | 03:55 AM
ThePerchik's Avatar
Once again, i was trying to take the a-pillar off for a while and got it about an inch away from its normal position, ther curtain side airbag is only about 4-5 inches from the top. Then its just empty.
Old May 24, 2006 | 04:03 AM
^^ yeah.. the curtain goes into the a-pillar a few inches.. other than that.. yeah.. nothing really.. o.0
see?
Old May 24, 2006 | 06:46 AM
titolito's Avatar
If you were going to remove all the airbags, I'd call you an idiot. But if you're certain you will NEVER carry passengers in the rear and you want to remove JUST the rear portion, than I say "good luck."
Be careful! Disconnect your battery before messin' with that; lest the airbags deploy and give you a roundhouse kick in the face. I don't know how likely that is, but better safe than sorry. Also, once you start messing with the accelerometers there is a chance your airbag warning light may go on and I think that only the dealer can reset that. Read that somewhere. Some guy disconnected his seats to take them out and his light turned on. BEWARE THE YELLOW WIRES AND YELLOW CONNECTORS!
Old May 25, 2006 | 03:36 AM
BlkTC's Avatar
hoolly crap.. That's a lot of work.. I think im just going to re-sell my pillar bar then.. aw !@#%!$!@ maybe ill wait till my car is a little older and worn out.. then i'll probably take them out when i strip my car.. damn. but thanks for everyone's help! I really appreciate it. Since, i was just going to yank it out..
msriotdoll1
Feb 20, 2020 11:35 AM
foxSCION
12
Jan 24, 2004 12:20 AM
LinexA
Nov 21, 2003 02:54 PM
