Difference between blowoff and diverter/bypass valve?
Old May 23, 2006 | 11:08 PM
Jake_tC's Avatar
Default Difference between blowoff and diverter/bypass valve?
Hey
Could someone explain in detail the difference between a blowoff valve and a diverter/bypass valve? Is there even a difference? Thanks
Old May 23, 2006 | 11:22 PM
sfe's Avatar
sfe
A blow off valve vents to atmosphere while a bypass valve recirculates the air back to the intake. BPV's come stock on most fi'd cars while BOV's are aftermarket. You can vent BPVs to atmosphere while not a good idea and likewise BOVs can be recirculated but that would require a way more detailed explanation.
Old May 23, 2006 | 11:25 PM
Jake_tC's Avatar
In the case of a supercharged car, does it make a difference whether you use a bypass valve or a blowoff valve?
Old May 23, 2006 | 11:37 PM
sfe's Avatar
sfe
It really comes down to personal preference. If you're using the MAF still it would be a better idea to recirculate it since releasing metered air will cause the the a/f to go rich during shifts/throttle releases. Though this is not that big of an issue and most people will use a BOV anyway.
Old May 24, 2006 | 01:38 AM
Jake_tC's Avatar
tuning with an safcII would solve that problem correct? is there a writeup on how to install a bov instead of bpv with the trd supercharger setup?
Old May 30, 2006 | 09:18 PM
NiKo's Avatar
well actually i just installed a hks ssqv (bov) and felt power loss but it is a sequntial valve so i talked to hks and they recomend using a bypass valve wit a sc
Fisqual
Sep 22, 2015 05:51 AM
Tc13
Mar 20, 2015 04:02 PM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
Risen_Son_Racing
Oct 12, 2003 01:21 AM
