mcculloch HID harness question.
Old May 25, 2006 | 06:44 AM
hiram's Avatar
Default mcculloch HID harness question.
my HID kit should be comming in today. i got the mcculloch 6000k set with the upgrade harnesses that take power from your battery directly. my question is since the power is taken directly from the batt. that means it wont need to be plugged into the stock harness for power. does this mean ill have my stock harnesses dangling around under the hood? any help is appreciated
Old May 25, 2006 | 08:06 AM
greddy05tc's Avatar
what upgraded harness are you talking about. i have that exact kit on my car and i never knew about any upgraded harness. my girl friend had the same kit on her car also.
Old May 25, 2006 | 09:50 AM
tC9o9's Avatar
ya what are you talkin about?
and if its not connected to the harness, how will it turn on?
Old May 25, 2006 | 10:00 AM
Tekka's Avatar
yes it will still need to be connected to your stock harness buy only to power the relay
the ballast is basicly connect straight to the battery (WITH A FUSE IN-BETWEEN I HOPE) and the ground is basicly the car chassis and ONE stock harness will connect to the relay that comes with your "Upgraded harness" so you can power the relay and turn on ur headlights.
Old May 25, 2006 | 06:02 PM
Jake_tC's Avatar
where did you buy your system and where did you see this upgraded harness that is available?
Old May 25, 2006 | 07:51 PM
bronxblaza117's Avatar
tC squad
yea tekka is right, the hid harness needs the power from the stock harness so it "knows" when to turn on
Old May 25, 2006 | 07:55 PM
hiram's Avatar
got the kit from xenonpros.com
Old May 25, 2006 | 08:36 PM
reagulator's Avatar
on mine, i tap in only one stock plug to turn on the relay. the passanger side plug is just dangling like you said.
Old May 26, 2006 | 10:54 AM
greddy05tc's Avatar
i bought mine and hers from xenonpros.com also. mine came with an adapter plug that plugs directly to the stock plug that goes to the stock light bulb. then those wires run inline with the igniter and relay. after the wires come out of the relay you should have two wires that are set up to plug directly to the hid bulb that comes in the kit. you should not have any plug of any kind dangling anywhere. if you do i would be calling them up wondering whats going on.
from my experiance they are a good company. bought two kits and no problems.
Old May 26, 2006 | 04:09 PM
reagulator's Avatar
i custom made my relay
Old May 26, 2006 | 05:33 PM
brian's Avatar
how much is the kit gonna run you? i saw a sale in the sponsored area for $245 shipped...
EDIT: oops, 245 was for 5300k, 275 for 6000k. https://www.scionlife.com/forums/viewtopic.php?t=101502
Old May 26, 2006 | 06:02 PM
greddy05tc's Avatar
i have the 6000k's on mine. when i bought them i payed around 345. that was with overnight shipping. i couldn't help it. when i buy stuff i want it as soon as possible. :D
mischman
Sep 15, 2015 03:38 PM
brett561tc
Sep 15, 2015 06:33 AM
roadrunnergt
Jul 20, 2015 05:25 AM
GoodVibes
Mar 10, 2015 04:29 AM
fearturtle44
15
Feb 13, 2004 01:15 AM
