Fixing Edges Of Plexiglas
Old May 29, 2006 | 04:18 PM
TeeCee06's Avatar
Default Fixing Edges Of Plexiglas
The edges of the plexiglass thats covering part of my sound system show up white when up against the black carpet, they are not smooth and are really gritty from cutting them. I tried painting the edges black to go against the carpet but it still shows white through the glass if you look at an angle... How can I sand this down to make the edges clear like the plexiglas itself?
Old May 29, 2006 | 04:22 PM
Citroen1's Avatar
Use a file to smooth out the rough parts and sandpaper to finish. Make sure it is clean and use a torch to flame the edges. This will give it a nice glassy look. Be carefull not to scorch the plexi.
Old May 29, 2006 | 04:24 PM
TeeCee06's Avatar
thanks alot.... those edges were annoying the hell out of me... ill try it tonight and see if it works.
Old May 29, 2006 | 08:21 PM
bB2NER's Avatar
Music City Scions
Correct, If you work your way up to some 1000 grit you could polish out the scratches and make it match the rest of the plexi.
Old May 29, 2006 | 08:37 PM
Tomas's Avatar
Admin Emeritus
Or, file, sand, polish with polishing compound on a polishing wheel. That's how I used to do it, uh, 45 years ago in shop class.
Old May 29, 2006 | 09:09 PM
Citroen1's Avatar
If your really carefull, flaming the edges with a torch works the best when you already have rough parts sanded down. Gives it a nice glassy look
Old May 29, 2006 | 10:48 PM
TeeCee06's Avatar
Ok, i did it by sanding it but i got a scratch on the main part.... is there anyway to take the scratch out of it? its not a deep scratch
Old May 29, 2006 | 11:08 PM
Citroen1's Avatar
You would have to find a buffing polish made for plastics and buff it out.
Old May 30, 2006 | 01:19 AM
FromThisSoil's Avatar
Make sure to do a test area on whatever you're doing, Plexiglass usually doesn't take well to polishing unless you use the right product with the right technique.
mc1114
Scion tC 1G Aero & Exterior
Apr 23, 2020 10:34 PM
Jvg2727
Scion xD Drivetrain & Power
Aug 24, 2015 04:40 AM
excb7
Jul 19, 2015 11:17 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
Jumphiggggg
Scion tC 1G ICE & Interior
Jul 15, 2015 02:29 AM
