Noise after Custom Short ram intake install ::FIXED::
Old Aug 16, 2006 | 01:22 AM
dachmo's Avatar
Default Noise after Custom Short ram intake install ::FIXED::
I just installed a custom short ram on my S/C and its making a really annoying rattling sound but nothing is loose.... has any one else had this problem?
please help...
- Dante
Old Aug 16, 2006 | 01:42 AM
jwaggz82's Avatar
you are going to have to narrow where you think its comming from ...front of the car ..back of the car .... .... .... im going to guess you hear it comming from where the intake is?
Old Aug 16, 2006 | 02:38 AM
dachmo's Avatar
yes... I hear it from where the intake is. It's very noticeable while the engine is under load and decelerating.
Thanks
- Dante
Old Aug 16, 2006 | 02:41 AM
jwaggz82's Avatar
when you rev it in park or just when you are moving? ...what gear are you in?
Old Aug 16, 2006 | 04:33 AM
06SuperWhite_SoCal_tC's Avatar
It may be the normal clicking sound that you hear at idle, but is amplified by the intake?
Old Aug 16, 2006 | 12:19 PM
Simplyscion's Avatar
Team No Limitz
thats what I was thinking maybe...but it wouldnt be that loud the way he is describing it.
Old Aug 16, 2006 | 02:10 PM
dachmo's Avatar
I hear it at idle a little bit, and a lot more under load. It sounds like a vibrational noise, but I cant find anything that is loose. The car was running fine..... I decided to put the Short ram on, and now it makes noise......
I'm going to put the stock airbox back on when I get home from work and see if it goes away..... in the mean time, please post any other solutions/ideas you may have.
Thanks again
- Dante
Old Aug 16, 2006 | 05:15 PM
dachmo's Avatar
ok...so i put the stock airbox back on over my lunch break and the noise is gone....that's definately a relief.
Thanks for all your input.
- Dante
Old Aug 16, 2006 | 07:35 PM
Jake_tC's Avatar
It was probably just the normal sound at idle. Switch to a heavier weight oil, put the intake back on, and see how it sounds. I don't even consider 5w30 oil, ESPECIALLY during the summer.
Old Aug 16, 2006 | 07:43 PM
rhythmnsmoke's Avatar
Music City Scions
- Dante
putting the Stock airbox back on is not what I would call a "FIX"....
What Intake is this? Did you make it yourself? Ebay bought intake? what?
Old Aug 16, 2006 | 11:18 PM
jwaggz82's Avatar
im wondering what it could be because there isnt much complexity to a tube and filter ....so I wonder where your sound is comming from. Are there any other details of when you hear the noise and what it sounds like? Did anybody hit the gas so you could look under the hood for where the noise was comming from? Remember - the intake moves a tad so if anything is within 1/2 inch from it ... there is a good chance it was vibrating. If thats the case you can just cut the tube an inch and that will solve your problem.
Old Aug 17, 2006 | 12:41 PM
Team No Limitz
yea when you installed it did you use any sort of bracket to hold it down? I reused the original brackets that came with the k&n and it worked fine
Brammi
Nov 13, 2016 03:46 AM
arinvolvo
24
Nov 2, 2003 05:30 AM
eric_m
29
Oct 12, 2003 08:22 AM
kidkamel
Oct 10, 2003 06:41 PM
2fixA
Sep 25, 2003 08:06 PM
