eD Quick Question
Old Sep 12, 2006 | 08:46 PM
Brent0252's Avatar
Default eD Quick Question
Ok this one really needs 6-12 answers so if anyone knows i'd appreciate it.
using both the NiNe.1 AND NiNe.2x amps answer each of the following....
1.) How many watts would i get with 2 13kv.2's
A. With NiNe.1 (D2 or D4?)
B. With NiNe.2x (D2 or D4?)
2.) How many watts would iget with 2 13ov.2's
3.) How many watts would i get with 2 16ov.2's
sorry it's a rather long question but if anyone can help me it'd be great. thank you.
Old Sep 12, 2006 | 11:05 PM
lil_will's Avatar
ScionERA
With dual 2 ohm coils you can wire the sub down to 1ohm and with dual 4 ohm coils you can wire down to 2 ohms. So check and see what those amps put out at 1 and 2 ohms and that should give you your answer.
Also, check this link it may be more helpful...
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Old Sep 12, 2006 | 11:20 PM
Brent0252's Avatar
thanks that helps me some.
Old Sep 12, 2006 | 11:26 PM
Brent0252's Avatar
Model Name : NINe.1 Amplifier
RMS Power @ 12.5v : 1200 x 1 @ 1Ohm
900 x 1 @ 2Ohm, 450 x 1 @4Ohm
Model Name : NINe.2X Amplifier
RMS Power @ 12.5v : 2 x 200 @ 4 Ohm, 2x 300 @ 2Ohm
RMS Power (Bridged) @ 12.5v : 1 x 600 @ 4Ohm
Model Name : 16Ov.2 Subwoofer
Available Voice Coils : Dual 2 - or - Dual 4
Power Handling : 650/1100 WRms
Model Name : 13Ov.2 Subwoofer
Power Handling : 600/1000 WRms
Model Name : 13Kv.2 Subwoofer
Power Handling : 400/800 WRms
Old Sep 12, 2006 | 11:28 PM
Brent0252's Avatar
what is ..."WRms"?
Old Sep 13, 2006 | 01:57 AM
lil_will's Avatar
ScionERA
That is Watts/RMS. For instance if the sub you want handles 1000 WRms at 1 ohm, then you would want to find an amp that puts out about 1000 WRms at 1 ohm.
Old Sep 13, 2006 | 03:09 AM
Brent0252's Avatar
alrite will this be good...
*2 of those with this amp....
http://woofersetc.com/index.cfm?fuse...Product_ID=447
Old Sep 13, 2006 | 05:19 AM
nebster's Avatar
why would u get those subs AND not get nine.2x or nine.1
Ed makes their amps for their subs. they don't make their subs for the PG amps
Old Sep 13, 2006 | 05:59 AM
lil_will's Avatar
ScionERA
They also have package deals at www.edesignaudio.com you might want to check them out. If it is ED gear you want, talk to mandos on this forum and he will be able to help you out.
Old Sep 13, 2006 | 09:52 PM
Brent0252's Avatar
yeah ive also thought about 2 160v.2's and a NINe.1 but not sure how much power that would get me...like 900 i think. those say 1100WRms is the only thing im worried about would one NINe.1 underpower these?
Old Sep 14, 2006 | 04:35 AM
nebster's Avatar
lol i'm running 2 16ov.2's and let me say this. Its too loud. i'm around 150 spl.
Old Sep 14, 2006 | 04:29 PM
mandos's Avatar
You liar...You'll end up at a 145
Old Sep 14, 2006 | 04:33 PM
mandos's Avatar
Default Re: eD Quick Question
D2's, 2 ohm final load, 900W total
D4's, 4 ohm final load, 600W total
D4's, 1 ohm final load, 1200W total
Don't bother. Get a single D2, 4 ohm final load, 600W total
Same as the 13Ov.2. Don't bother. Get a single D2, 4 ohm final load, 600W Total
Old Sep 14, 2006 | 04:34 PM
mandos's Avatar
Click on the blah blah final load for a picture of how to do that
Old Sep 14, 2006 | 04:35 PM
mandos's Avatar
BTW, all of those set ups would work perfectly fine.
Underpowering is only bad if you crank your gain because it isn't loud enough.
1 or 2 16Ov.2's in a tC is only not loud enough if you're deaf.
Old Sep 14, 2006 | 05:13 PM
nebster's Avatar
i'll get a 150. watch
Socialdisorder
Apr 3, 2015 01:35 AM
S7ephavs
Mar 22, 2015 12:09 PM
GoodVibes
Scion xB 2nd-Gen Wheel & Tire
Mar 3, 2015 09:47 PM
ShadowMage
16
Jul 25, 2004 06:02 PM
quadraphonic
15
Jan 22, 2004 05:52 PM
