I have a problem...
Old Sep 13, 2006 | 02:03 AM
soros151's Avatar
Default I have a problem...
Okay, I just installed my new LCD screen in the center, and I wanted to move my stock radio into the glove box. Okay I spliced ALL the cables from all 3 plugs from behind the radio and extended them like 2 feet for it to reach the Glove compartment. The thing is I know I have all the cables to the correct cables in the plug, cause I did them all one by one. But now the radio is dead and I already checked all the fuses inside the car and they where fine. Now what should I do?
Old Sep 13, 2006 | 02:04 AM
ProshopXB's Avatar
How did you connect the wires?
Old Sep 13, 2006 | 02:08 AM
soros151's Avatar
I used 18 gauge to help in the lose of power per feet, and I did one cable at a time, so Iwouldn't comit an error.
Old Sep 13, 2006 | 02:11 AM
ProshopXB's Avatar
How did you connect the wires together... soldier and tape, crimp caps, butt connectors.
Old Sep 13, 2006 | 02:16 AM
soros151's Avatar
okay, since I didn't have a solder at the moment, I used the old method of stripping the wire and roll them together, but it will be very difficult to get them sepparated.
Old Sep 13, 2006 | 02:21 AM
ProshopXB's Avatar
Ohh the old twist and tape method.. Well since there are no blown fuses and your sure you hav all the wires matched correctly.. then it sounds like you have a bad connection of one of the power wires. I would double check all the connections and make sure the wires match up.. Is it a factory stereo or after market?
Old Sep 13, 2006 | 02:38 AM
soros151's Avatar
factory stereo, I will do that, check the wires again.
Old Sep 13, 2006 | 11:21 PM
soros151's Avatar
Well guys, I have bad news, no results on double cheking the wires. The only fuse that was out inside the car was the cigarrete lighter, and I can't find no other solution to the problem. I might have to take it to a car audio store and have them fix it and/or buy a new radio if this one has to go.... Any of you have any other idea?
D_Roke
Mar 31, 2015 05:37 PM
Hypn0tiz3d
Oct 30, 2007 08:15 PM
sensez
Oct 2, 2005 12:01 AM
2005ScionTC
Aug 13, 2005 06:45 PM
BlueScionXB
May 8, 2004 01:43 PM
