Injen Cai Rattling?
Old Oct 8, 2006 | 08:35 AM
Syldrin's Avatar
Default Injen Cai Rattling?
anyone elses injen cai rattle when they turn their car on or shift at low rpms? anyone have any ideas what might cause this, or is it to be expected? also when does the funny smell go away?
Old Oct 8, 2006 | 09:00 AM
phiquach's Avatar
i don't get a funny smell but if it rattles, you didn't install the foam around the fender because that is where the cai hits and makes the rattle noise.
Old Oct 8, 2006 | 09:02 AM
Syldrin's Avatar
i catch the smell of the filter. alot
Old Oct 8, 2006 | 11:43 AM
Whocares05050's Avatar
There is a silcone strip that goes around the fender wall. didnt you install this?
Old Oct 8, 2006 | 03:03 PM
senseiturtle's Avatar
It's more to it than that.
That is a rub point, and the bend just downstream from the filter can also rub against the fender. I used a little bit of the foam insulation wrap to make a little pad and wedge it in there.
Old Oct 8, 2006 | 06:25 PM
Syldrin's Avatar
it sounds like metal on metal so i don't think it's the filter. i did put the rubber strip on.
Old Oct 8, 2006 | 06:58 PM
i007spectre's Avatar
I have that to, I think its hitting the fender down inside. problem is i dont know what to do to stop it.
Old Oct 8, 2006 | 07:15 PM
No, the filter if installed CORRECTLY shouldnt have any troubles. the silicone strip WILL sometimes come out. what i did was cut the strip in half, and it stayed in there better.
What I would do is start from the throttle body again, and make sure everything is tightened down more securley. If that still dosnt help, cal injen.
Old Oct 8, 2006 | 07:38 PM
fherjohn's Avatar
i had the same problem when i first got the intake. make sure the rubber is installed correctly. the part that hits is that hole where the intake goes into. you know what im talking about? well that part rubs. or try to get like some thick tape with foam and tape it to the intake directly because the rubber piece tends to fall off.
Old Oct 8, 2006 | 08:06 PM
Syldrin's Avatar
yea the rubber peice kept falling off it turns out. so i just put some contact cement on it. hopfully it works
Old Oct 8, 2006 | 08:11 PM
jwaggz82's Avatar
you can use pipe insulation also if you need to make sure the pipe doesnt hit into the side where it goes into the wheel well. Also - make sure your bracket isnt broken ...
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Chrono
Aug 25, 2015 05:59 PM
