l.e.d. in tail turn and front turn signal
Old Dec 7, 2006 | 04:54 PM
boombox069's Avatar
Default l.e.d. in tail turn and front turn signal
anyone had any problems with putting the led bulbs from ebay on their turn signals.......(like fast flashing or blowing fuses any thing....................and these are the ones i am talking about or ones simular
http://cgi.ebay.com/ebaymotors/NEW-A...QQcmdZViewItem
Old Dec 7, 2006 | 05:01 PM
EZ-BAKED's Avatar
I hope not i orderd a hole set up for my ride like 3days ago. turn brake 3rd brake park all that stuff.
Old Dec 7, 2006 | 05:09 PM
hotbox05's Avatar
yeah when you use led bulbs you need a resistor or a new flash relay. www.autolumination.com sells the new relays for 19.99
Old Dec 7, 2006 | 07:08 PM
zereaux's Avatar
Revolt Imports
DeepSouth Scions
^^^ thats the place i got my brake lights from... they suck... blew out the fuse, replaced the fuse, turned the bulb around, they worked until i hit the brakes, and blew that fuse out... the other LEDs i had before those had a built in resistor into it... craftsmanship of those are crap... just my 2 cents... you shouldnt have to buy extra equipment if they are properly made...
Old Dec 7, 2006 | 07:39 PM
hotbox05's Avatar
yes you do. i don;t know which ones you've bought i've used his stuff for years.
whenever you use led bulbs you need a resistor or relay to blink correctly.
if you put the bulb in backwards how would you expect it to work. leds are much different than incandescent bulbs.
all leds have a built in resistor so as tehy can work with 12v. 12v is way too much for an led......
and each cars relay is different some can work well with led bulbs the vast majority cannot.
Old Dec 7, 2006 | 09:23 PM
SquallLHeart's Avatar
they also sell led compatible relays at www.superbrightleds.com
CF18-08
Old Dec 7, 2006 | 11:14 PM
boombox069's Avatar
hey guys thanks alot,
so to find out what relay i need...i just find the relay for the turn signals and look at the markings on it and then look for the same led relay to have the same markings...... yes?or........
Old Dec 7, 2006 | 11:55 PM
same pin layout.. but i just told you which one it was in the post above you.
Old Dec 8, 2006 | 02:30 AM
hotbox05's Avatar
or go to autolumination.com and buy te newer toyota's relay same part .
Old Dec 8, 2006 | 04:36 PM
zereaux's Avatar
Revolt Imports
DeepSouth Scions
have you used his brake light LEDs? thats the only thing that i have gotten from him... the LED ones i have right now have a resistor built into the bulb itself... i liked his better cause it looks just like the ones for the lexus, a crap load of LEDs on it... let me know cause i still have them, i just put them off for now...
Old Dec 8, 2006 | 06:50 PM
hotbox05's Avatar
i have his brake light leds matrix II
rear signal matrix , front turnsignal switchback , front side markers , high stop rear , license plate EVERY exterior bulb.
Old Dec 8, 2006 | 07:15 PM
zereaux's Avatar
Revolt Imports
DeepSouth Scions
i have the same ones, brake lights anyways... how did you get yours to work? guessing just a resistor added inline with the wire... january is when i was going to plan on converting all bulbs to LEDs, would love to get some feed back from you if you dont mind, couple of tips and pointers perhaps...
Old Dec 8, 2006 | 07:52 PM
hotbox05's Avatar
they worked just fine. i just bought the blinker relay from them as well everything is all good.
Old Dec 8, 2006 | 08:11 PM
bBlover's Avatar
I know this is O/T: but I love your avatar!
xBSciontist
Jun 18, 2019 03:06 PM
randomsuper
20
Jun 13, 2015 10:56 AM
TheTripleC
Jan 4, 2015 06:46 PM
minter66
Dec 15, 2014 01:45 PM
Opr8r
20
Feb 25, 2004 11:29 PM
