headlight problem
Old Jan 22, 2007 | 04:28 AM
pimptc's Avatar
Default headlight problem
the other day i was parked and i was going to turn off my headlights and i noticed one of them was off. well i checked all the wireing and everything is right, and everything else is working perfectly, the only thing is the passanger headlight. i unpluged the clips and tested the clip supplying the power and its not supplying any, what could of happened? fuse somewhere (checked them already but could of missed one). i have no clue where to look or what to do.
Old Jan 22, 2007 | 06:53 AM
KINGxOFxSKA's Avatar
Unique Scionikz
What kind of bulbs are you running?
Old Jan 22, 2007 | 06:56 AM
captainlaziness's Avatar
Is the bulb burned out?
Old Jan 22, 2007 | 07:28 AM
SquallLHeart's Avatar
fuse 2 is for the right lowbeam
fuse 3 is for the left lowbeam.
Old Jan 22, 2007 | 08:01 AM
Skottyboy7's Avatar
you might want to check the headlight fluid
Old Jan 22, 2007 | 08:07 AM
And if it's empty, you might as well upgrade to 1000K HID fluid.
Old Jan 22, 2007 | 08:37 AM
ADRdesignCo's Avatar
^ HAHAHAHAHAH
i say check if the bulb is burned out, and check the fuses.
Old Jan 22, 2007 | 07:16 PM
pimptc's Avatar
i checked fuses, replaced them anyway, and the bulb was bad and replaced it. still nothing, there is no power going to it??? this is what they look like
Old Jan 22, 2007 | 09:24 PM
pimptc's Avatar
*bump*
for help
Old Jan 22, 2007 | 10:41 PM
did you use a multimeter?
Old Jan 22, 2007 | 10:45 PM
did you read the manual?
Old Jan 23, 2007 | 03:45 AM
pimptc's Avatar
manual did no help, and i got no reading of power at all.....did i short it somehow or what? i should just go to the factory and see if they can fix it....cause its obviously not a fuse or wireing problem....i guess
Old Jan 23, 2007 | 04:14 AM
punkemoskaHXC's Avatar
Hmm...Same thing happened to me.
Old Jan 23, 2007 | 04:21 AM
Scionarra's Avatar
check ur wiring as it probably melted somewhere...most likely it will melt somewhere lose to the headlight bulb itself... some parts cant be seen but if you try and move the wire around and it feels kind crispy then its burnd out... best bet is to bring it to the dealer as u might efff up something else. just put the stock bulbs back in so they can cover it with the warranty... thats wat i did
Old Jan 23, 2007 | 05:40 AM
check for voltage with a multimeter. then try to trace the cable for any faults.
S7ephavs
Mar 22, 2015 12:09 PM
2006whitexb
Mar 11, 2015 12:39 AM
missing_image
Feb 7, 2015 07:18 PM
scsteven
Jan 25, 2015 01:06 AM
