Tire Kingdom Experience.... kinda
Old Mar 14, 2007 | 06:02 PM
WiCkEd_TrInI's Avatar
Default Tire Kingdom Experience.... kinda
I'm not exactly sure where this belongs but anyhow my car is dropped on hotchkis springs, so today i went to tire kingdom to get an alignment and the i told the guy at the front desk i was lowered and he said that they dont do that there and he went to get the specalist, the specalist looks at my car and says it does not have the bolts to adjust the camber and that i needed a camber kit.. i was like hmmmmm, i swear someone on here said u dont need the camber kit with hotchkis drop and that there are bolts to adjust the camber.. is he rite or does it not have adjusable camber to some degree, also he said that i would rub against the quarterpanel if my camber was straight.. Help.. Thoughts....
Old Mar 15, 2007 | 08:03 PM
no1 has anything to say??? jeeze
Old Mar 15, 2007 | 08:08 PM
draxcaliber's Avatar
i'd help, but i just don't know...
Old Mar 15, 2007 | 08:33 PM
lol well thank u very much...(im not bein sarcastic)
Old Mar 15, 2007 | 08:45 PM
the smarter guys must be at a symposium today. lol.
Old Mar 15, 2007 | 08:54 PM
Thermos2003's Avatar
I had mine dropped with TRD springs/struts. They had no problem adjusting the alignment except that it was the first tC that the guy had ever done. It took him a while but he had no problem. Hotchkiss isn't that low is it? I think as long as it's less than 1.5-1.75 inches you shouldn't need a camber kit. Not positive with the numbers though. All i know is anything similar to the TRD drop doesn't need a camber kit.
Old Mar 15, 2007 | 09:01 PM
hotchkis is nearly a 2 inch drop all around.
i just got my trd springs and struts installed, i'm waiting a week for them to settle to before getting an alignment.
wicked, you might want to call around and ask a toyota dealership, or some other garages, maybe search for other tc owners with the hotchis springs and ask them what they went through installing their springs. since nobody seems to be able to help you, you just might have to help yourself.
Old Mar 15, 2007 | 10:48 PM
Daskid's Avatar
I'd say print these out and show them how to do it:
http://www.trdsparks.com/displaypart...1&parts_id=677
Includes front and rear wheel alignment instructions.
I have Hotchkis installed too, and the guy who did the alignment on mine said that he can't adjust the rear camber because it couldn't be done... I whispered like.. WTF?!? Are you a real mechanic or what?!?! So I guess I'll go back when I have the time and show him the instructions. Good thing it's a lifetime alignment, so I don't have to worry paying again.
Old Mar 16, 2007 | 12:38 AM
hmm thanks all...
I dont get it...
Old Mar 16, 2007 | 12:40 AM
yea the "specialist" said that my car didnt have things to adjust the rear camber... i was like oooo....lmao.. so u didnt get it fixed? thanks
Old Mar 16, 2007 | 12:47 AM
I dont get it...
it is a gathering of smart people to listen to other smart people discuss things that us simpletons could not comprehend.
Old Mar 16, 2007 | 02:39 AM
Daskid's Avatar
I didn't get it fixed yet. I'll prolly get it fixed after I get my oil changed. The mechanic pretty much aligned the toe and camber in the front. But the rears are still in bad shape. The toe is better than before, but the camber is still the same. Some gurus here once said that unbalanced toe is the culprit of tire wear and camber is just second. So I'm not that worried as before. But yet, there's still things that needs to be fixed. :D
Old Mar 16, 2007 | 02:41 AM
i wonder what it will be like to drive my tomorrow on the interstate with my new trd drop and no alignment...guess i should stay away from the triple digit speeds...probably best because the state troopers know spring break starts tomorrow.
Old Mar 16, 2007 | 03:02 AM
Daskid's Avatar
^^ Not getting an alignment will only affect your tires' life span. But driving at 3-digit speeds might be dangerous with nonaligned wheels. Better safe than sorry.
Old Mar 16, 2007 | 08:17 PM
Otocan's Avatar
okay, first off there are bolts to adjust the camber on the front and rear, they're right there by the toe-links, look under the car up and behind the hub with the wheel off and you'll see them, they're big with grooves in a cam plate for adjustment.
They only have so much adjustment to deal with, and I measured my TRD springs and it dropped it 1.8in in the front and 1.7X in the back, and I could not get the alignment past 2° in the rear without longer bolts, it's that simple. I measure my own alignments.
a "camber kit" just allows for more adjustability, but it also doesn't HOLD that setting like it should, it has a tendency to slip over time. You don't need a camber kit, you need new bolts in the rear.
Of course, that would have been the answer you got if you went to a competent mechanic in the first place.
And again, Camber doesn't kill tires, toe does. Camber changes every time you sit in the car, take a corner, hit a bump, or put groceries in the back. Toe doesn't. Toe pulls on your tires and wears them.
and to Draxcaliber, triple digit speeds are stupid. TRD springs don't need an alignment unless the toe has changed. If the toe is fine, leave it, you'll like the added camber.
Old Mar 16, 2007 | 08:42 PM
Daskid's Avatar
^^ Speaking of the devil.
We're all glad you belong here in SL.
Old Mar 16, 2007 | 09:04 PM
Thank u very much Otocan, and everyone else...
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
NinjaPilot
Feb 29, 2016 02:58 AM
Crhutto
Mar 12, 2015 10:22 PM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
