Headlight Problem
Old 02-05-2008, 03:47 AM
OC_ScionBox's Avatar
Default Headlight Problem
how do you fix when one headlight is brighter than the other??
i know its not the bulb because i swap them out and still looks
the same
could it be the harness maybe??
i really need to fix this because its annoying
any help out there??
OC_ScionBox is offline
Old 02-05-2008, 03:50 AM
Dkfung88's Avatar
brighter? are they aligned?
Dkfung88 is offline
Old 02-05-2008, 03:59 AM
draxcaliber's Avatar
uhm...before we help you, you do know your driverside bulb is supposed to be aimed a bit lower than your passengerside bulb so they don't blind oncoming traffic right?
draxcaliber is offline
Old 02-05-2008, 04:04 AM
what are you guyz talkin about?????????????
i dont think that made a difference, still comes out the same
Old 02-05-2008, 04:13 AM
what i'm trying to say is that the low beams on all cars are designed to focus and aim the light created from the bulbs in the housing. the headlight housing on the passenger side is aimed higher and further than the driverside because the driverside light is closer to oncoming traffic, so it is designed to aim lower than the passengerside bulb to make sure not to dazzle oncoming cars.
this isn't a property of the bulb, it is a property of the headlight housing itself.
so i am trying to make sure that you are taking about one of your headlights being noticibly dimmer than the other one, or is it because you didn't realize that your headlights don't focus light in exactly the same pattern.
Old 02-05-2008, 04:59 AM
okay, from your lack of response, i'm going to guess i was right?
Old 02-05-2008, 05:01 AM
burstaneurysm's Avatar
Uhm... yea.
burstaneurysm is offline
Old 02-05-2008, 10:12 PM
i think that it could be the harness maybe??
how can i fix it??
Old 02-05-2008, 10:26 PM
if it is the harness, you replace it, or make sure there is nothing preventing it from getting a good connection.
Old 02-05-2008, 10:36 PM
about how much is a replacement harness and where can i get one?
Old 02-05-2008, 11:05 PM
before you go trying to replace parts that might not even be the problem, why don't you take it to get diagnosed first and make sure you replace the right parts.
Old 02-06-2008, 01:07 AM
Metro273's Avatar
The reason for one dim headlight is a bad ground somewhere in the headlight harness. Follow the headlight harness to a ground or common ground, remove the bolt holding the harness to the body, clean the bolt, mating surface and ground eyelid real good and reattach harness to body.
If that don't work, time to take it to the dealership for a proper diagnosis...good luck!
Metro273 is offline
Old 02-06-2008, 04:23 AM
where is the bolt holding the harness to the body located at??
Old 02-08-2008, 03:08 AM
Scorpius01's Avatar
It is all in the wiring diagram. If you do not have access to it, then take it to a dealer.
Scorpius01 is offline
Old 02-09-2008, 06:53 AM
AKScionxb's Avatar
i have HIDS installed in my box but then when i came out with the autostart going, my drivers side light was flickering and the passenager side wasn't, i switched out the bulb thinking it was in the HID wiring system but when i wire it back to a original oem bulb still flickering any ideas?
AKScionxb is offline
Old 02-11-2008, 09:57 PM
Scorpius01's Avatar
Did you splice the HID kit into the factory harness? Do you have access to a multimeter? I can provide the wiring diagram.
Old 02-13-2008, 02:11 AM
AKScionxb's Avatar
no i don't access to a mulitmeter? i dont even know what that is. and i got the HID plug and play kit from oznium. i'll get a pic and show you guys what i'm talking about later tonight.
Old 02-13-2008, 05:36 PM
Scorpius01's Avatar
flickering is caused by a bad connection or an intermittant short (broken wire, etc...)
Old 02-17-2008, 07:17 AM
AKScionxb's Avatar
so how do i fix it?
Old 03-30-2016, 05:02 AM
Music City Scions
bB2NER's Avatar
Found out that one dim headlight is usually a blown headlight fuse. Fixed mine when I did a yahoo search that led to club xB and the answer.
bB2NER is offline
S7ephavs
03-22-2015 12:09 PM
2006whitexb
03-11-2015 12:39 AM
missing_image
02-07-2015 07:18 PM
scsteven
01-25-2015 01:06 AM
Quick Reply: Headlight Problem
