I need Ur Help Fast!!!!!
Old Dec 19, 2004 | 01:07 AM
TrappedInABox's Avatar
Default I need Ur Help Fast!!!!!
I bought some aftermarket fog lights and i wanna wire them up to the stock wiring harness. the only thing is is that i need some relay that goes in ur fuse box. anyone out there have Aftermarket fogs know where to get this relay. i looked in the tech fourm and all it shows is the stock fog light kit, no aftermarket stuff. Any help would be good, thanks.
Old Dec 19, 2004 | 01:35 AM
UnFocused's Avatar
I dont think youll find what you looking for (buy itself)... you need a relay, and a whole bunch of other accesories...I doubt the dealer will be able to order those seperatly...
Old Dec 19, 2004 | 01:45 AM
dgHotLava's Avatar
if your tring to use the factory wires an such, you'll need to get the relay from the dealer...
they have a special 4 pin relay....
it goes in the fuse block under the hood....
Old Dec 19, 2004 | 05:49 AM
NJthunder5spd's Avatar
the relay is a small greenish/teal 4 prong that goes under the dash on the left side of the fuse panel
go to toyota and ask them for the foglight relay.. im sure they have it listed
Old Dec 19, 2004 | 08:30 AM
PM scionspecialistvegas, he is in your area and knows the scion electronics like crazy. :D
Old Dec 19, 2004 | 09:03 AM
etarui's Avatar
I may be way off on this one...but I don't think you need to use a relay. I believe the relay is used to turn the fogs off when your hi-beams are on. I'd prefer to have the fogs on even with the high beam on. I would just buy the stock switch, and wire it to the fogs.
Old Dec 19, 2004 | 02:10 PM
the kit that i bought has a switch that comes with it but its a 3-prong switch and the stock switch is a 2-prong. i tried to wire it all up and see if the fogs would come on, but it didnt work. i have to go in for my 5000 mile service on wednesday, so maybe ill just call and get that relay. i was just wondering if it could be done without the relay. i guess no one has wired up aftermarket fogs using the stock foglight harness. if so let me kno.
yupinmytC
22
Jul 27, 2024 07:08 PM
carid
Feb 10, 2019 10:46 PM
mxwes
Aug 30, 2015 09:11 PM
RokGoblin
Aug 11, 2015 02:45 PM
danaxb
Aug 10, 2015 06:33 PM
