Nitrous
Old Feb 21, 2009 | 09:28 PM
montyfire04's Avatar
Default Nitrous
i'm trying to figure out where i can tap into my fuel line for the wet shot part of the nitrous system, i'm wondering if i'm gonna have to replace the hard line fuel line for a flex hose type? or is there somewhere i can tap into without removing the hard line.?
Old Feb 21, 2009 | 09:31 PM
lastlookcustoms's Avatar
Default Re: Nitrous
You can cut into the rubber line that comes off the hardline in the engine bay. Trace the fuel line from the rail and you can tap into that rubber line there.
Old Feb 21, 2009 | 11:44 PM
superwhiteTC20's Avatar
^^There's your answer
Old Feb 23, 2009 | 04:35 AM
so from the fuel rail it goes to the fuel damper then to hard line and bends towards the fire wall....so it the rubber hose near the firewall?
Old Feb 23, 2009 | 03:54 PM
Yes. Use the rubber hose after the fuel damper
Old Feb 23, 2009 | 10:28 PM
ok well heres the problem the line after the damper is a hard line that is pre-bent.
Old Feb 24, 2009 | 05:28 PM
Well somewhere between the fuel rail and the firewall is going to be some rubber fuel line. Thats where you want to tap into it.
Old Feb 24, 2009 | 08:04 PM
Dont worry about it guys , i figured it out. i just replaced the line that goes between the fuel damper and the actual hard line near the firewall... you see the one in between was a plastic hard line with quick releases on both ends and was sheathed in a rubber coating so i just replaced it. thanks for the help tho...one thing which sparks do u recommend that are one step colder than the laser iridium's i got in it now?
Old Feb 24, 2009 | 08:20 PM
equinox2355's Avatar
Basic rule of thumb, for every 75hp-100hp added, go 1 step colder. Other thing that some people go by is every modification, they do 1 step colder. Just my $0.02, trying to help lol
Old Feb 24, 2009 | 11:59 PM
thanks ...tho it still doesn't answer my Question. so what sparks do u recommend?
Old Feb 25, 2009 | 03:19 PM
I would go one step colder NGK plugs. Dont get platinum! If I were you, I would just go with the regular copper plug. They are cheap to replace if you foul one out. I have better luck with the regular plugs.
I dont have my catalog in front of me but the ones you want should have a "7" in the long NGK number. If you go to a parts store and tell them you want the colder plugs, just make sure when they give them to you, they have the 7 and not a 6. A common mistake with NGK is that the higher the number, the hotter the plug. THIS IS NOT TRUE. The higher the number, the colder the plug. So if he tries to give you a plug with a 6 in it, those are stock. I hope this made sense.
Old Feb 25, 2009 | 10:46 PM
sweet deal thanks, i work at advance auto parts so i should be able to get my hands on some sparks. tho how does ur car run on the copper plugs for normal daily driving? cuz the stock ones are iridiums.
Old Feb 26, 2009 | 01:34 PM
The cars I have done seem to run fine on copper plugs. I use them on everything I build from the xB's to the supras with no issues.
Old Feb 26, 2009 | 04:59 PM
the only thing iridium is supposed to do is last longer. Other than that, there isn't any performance difference.
Old Mar 4, 2009 | 05:09 PM
wlfpck's Avatar
This is what I used on my h22 swapped accord. I know it's different than a tC but I am a loyal NGK customer. :D
Old Mar 5, 2009 | 02:45 AM
sweet, now question 2. i got a A/F gauge...which one of the 4 wires on the O2 sensor would i tap into for the gauge?
Old Mar 8, 2009 | 08:53 PM
borderguy881's Avatar
Air Fuel Sensor
White- Sensor ground
Orange- Sensor positive
Yellow- Battery
Green- Heater
hope this helps. i go to school for auto tech so i get alldata which is a program where i can get pretty much anything for any car. so this info is off of the system wiring diagram
Old Mar 8, 2009 | 11:52 PM
i got that program too i just couldn't decipher it cuz it showed the connector end but not enough details on it. thanks this helps.
Old Mar 9, 2009 | 03:47 AM
thendawg's Avatar
Just fyi - you wont be able to tap into our primary 02 sensor - it uses a current sensing device rather than a change in voltage. Its VERY accurate (similar to any aftermarket wideband) but very unique in the way it works. The guages you buy that tap into the factory 02 sensor are designed to be tapped into a narrowband sensor like our secondary 02 - these have a nominal voltage when running stoich than deviate when running rich or lean but are not very accurate. Hope that helps!
Old Mar 9, 2009 | 12:50 PM
so i the end it would be best to buy a wideband or the sensor in which the gauge should use?
VitaminE
Mar 24, 2015 03:36 PM
yhwhdesign
Mar 7, 2015 02:01 AM
spawnconnery
Scion xA/xB 1st-Gen Forced Induction
Dec 18, 2014 08:38 PM
aarontrini85
37
Jan 24, 2009 03:21 AM
aarontrini85
24
Feb 5, 2005 04:29 PM
