wet sanded headlight
Old May 12, 2009 | 04:52 AM
GammaTNT's Avatar
Default wet sanded headlight
I wet sanded my friend's corolla today.
The thing i used:
800, 1000, and 2500 grit sandpaper
3M rubbing compound
Meguiar's Plastx
and a bucket of water.
here is before.
i started with 800 grit, then 1000 grit and 2500 grit sand paper.
I used those sandpaper for about 12 minutes for each grit. Make sure to keep the headlight wet.
Here is what it looks like after the 2500 grit
and applying 3M's rubbing compound.
i cleaned the headligh with Invisible Glass, and apply Meguiar's Plastx (plastic cleaner and polish)
Here is the finish product.
if you having trouble find those 2500 grit sandpaper, you can use 2000 grit.
I got those 2500 from Crystal View Headlight Restorer Kit($18.50) that i used on my friend's 99 Altima.
Since the sandpaper are reusable, i just ask my friend to buy the Meguiar's Plastx.
These Corolla headlight wasn't as bad as my buddy's Altima. Altima took me about 1hr. and this Corolla took me about 45 minutes.
here is a link to Crystal View Headlight Restorer Kit. My buddy's Altima headlight look exactly like that car. LOL He need highbeam to read street signs.
Old May 12, 2009 | 04:58 AM
SVicksTC's Avatar
good ish ive been wanting to do this to my dads headlights on his dodge dakota but wasnt quite sure if this technique was going to work...
will try tomorrow
Old May 12, 2009 | 05:00 AM
Rockztar's Avatar
HID's would of solved the problem..
they came out looking great, good job man
Old May 12, 2009 | 05:06 AM
GammaTNT's Avatar
thank you for the kind words.
If you look at the front bumpers from 'before' and 'after'
Those white power are oxidized plastic from the headlight that i sanded off.
Old May 12, 2009 | 05:56 AM
Rockztar's Avatar
woa thats a lot of oxidation lol... when you applied the plastix did u do it by hand, or did you use some kind of power tool?
Old May 12, 2009 | 11:24 AM
GammaTNT's Avatar
i applied the Plastx by hand
Old May 14, 2009 | 03:52 AM
HeathenBrewing's Avatar
Good job. results look great!
Old Mar 1, 2013 | 04:14 AM
BigPa's Avatar
Default Humor me plz.
New here. Plz explain what an HID is.????
Thanks.
Old Mar 1, 2013 | 11:31 AM
Lil_Deuce_tCoupe's Avatar
It was a joke. HIDs are High Intensity Discharge lamps.
http://en.wikipedia.org/wiki/High-in...discharge_lamp
Old Apr 12, 2013 | 08:56 PM
gxcue1's Avatar
Great job! That was a huge improvement.
Old Apr 13, 2013 | 10:05 PM
Archangel1183's Avatar
Wow, Old thread. Does the OP even post here still?
I'm wondering how long the Plastx holds up before the headlights start yellowing again. I did the same thing to my headlights but used clear coat before polishing them. 8 months later and they've started to yellow again. I just purchased a UV protectant clear coat and was wondering if I should just go with PlastX.
Old Apr 20, 2013 | 03:52 AM
GammaTNT's Avatar
i am still around. PlastX doesn't last long. I re-sand the headlight in about 6 six months.
Old Apr 22, 2013 | 04:34 AM
Yanki01's Avatar
i just did this to my tC which needed some care. came out really really good. i was not expecting results like this...
Old Apr 24, 2013 | 08:06 PM
scionblur's Avatar
They make something else for that too. I can't think of the name right now though.
Old May 2, 2013 | 06:05 AM
GammaTNT's Avatar
nice job Yanki01, i am going to get the Meguiar's restoration kit too.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Andreas24
Sep 15, 2015 02:10 PM
