The Fastest is here...
Old Sep 26, 2009 | 12:50 AM
xbgod's Avatar
Default The Fastest is here...
It's here....it's ugly..... ouch....I just destroyed you.....
328 Hp fully built.
Old Sep 26, 2009 | 12:54 AM
xbgod's Avatar
And heres the list:
Fully Built Race motor:
Darton Sleved block
Crower rods
Arias Pistons
Ferara Valves + 1 mm oversized
Ferara retainers, Lockers, springs
3 way valve job
Ported and polished head
Schneider cams
Weapon-R sheet metal intake
Obx throttle body spacer
Tial / Garrett Turbo
Greddy Intercooler
Greddy type R BOV
CFT custom Exhaust manifold/ down pipe
Stand Alone ECU:
Microtech LT10 w/ Microtech Ignition and Bosch coil packs
Electromotive crank trigger
MSD wires / NGK plugs
Fuel System:
Walboro 255l , Aeromotive regulator , Perrin fuel rail ,
Aerospace Components custom fuel block for NX kit
680cc precision injectors
Snow performance methanol injection
DEI complete Cryo system
Nitrous Express 100 shot kit tps activated. auto bottle opener
w/ fire and ice cooling system for constant 1000 psi
Aerospace Components 13" full floater disc brake system front
and rear
N.B.S 2.5" custom stainless exhaust w/ Aeroturbine Resonator
and Skunk2 Can
Oil system: Perma cool
Perrin under drive pully
Level 10 5 speed transmission
Ferdenza clutch and fly wheel
Autometer gauges
12 point roll cage
JIC Majic dampner kit
Axels: Gator
Sparco seats, pedals and shift ****
TRD short shifter
Samco hoses
Axis 18" Reverbs
Nitto rubber
VIS carbon fiber hood and hatch
Greddy boost controller and timmer
Old Sep 26, 2009 | 12:58 AM
xbgod's Avatar
And here she is.......
Old Sep 26, 2009 | 01:29 AM
xbgod's Avatar
Did I mention ..... yeah... inside she's just as sexy.
Old Sep 26, 2009 | 01:31 AM
getaforknjob's Avatar
WOW!
Very nice xB!
Old Sep 26, 2009 | 01:36 AM
xbgod's Avatar
more to seeeeeeeeeeeeeeeee
Old Sep 26, 2009 | 01:38 AM
xbgod's Avatar
13" front and rear disc... Any body??? didn't think so...
Old Sep 26, 2009 | 01:45 AM
xbgod's Avatar
Did someone say Nitrous??????????????
Old Sep 26, 2009 | 01:47 AM
Perroski's Avatar
jajajja very nice xb man congrats
Old Sep 26, 2009 | 02:15 AM
blown_xa's Avatar
nice build. Can you post more on your turbo specs? Title says "fastest" you ran faster than a 12.8 in the 1/4? That's awesome if you did.
I noticed the head bolts are tiny on our motors, did you upgrade? Im worried that may be a weak link for high horsepower numbers.
Old Sep 26, 2009 | 02:21 AM
xbgod's Avatar
This is how it all stays together............
Old Sep 26, 2009 | 02:29 AM
xbgod's Avatar
OK, here are some turbo specs: It's a Tial / Garrett Turbo 739548-5102TV
Ind wheel dia. 47.2mm Exd Whl Dia. 60.0mm Trim 62 A/R 0.60 That is compressor side. Here is Turbine side: 53.8mm 76 Trim A/R 0.64
Old Sep 26, 2009 | 02:35 AM
CSUnited14's Avatar
wow i love it videos?
Old Sep 26, 2009 | 02:36 AM
jct's Avatar
jct
where did you run your coil packs to/at?
Old Sep 26, 2009 | 02:37 AM
bB384's Avatar
IV ACE
Nice... But way too much comfy stuff (Sound system, carpet, interior etc...) I'll still PWN you in the corners!
Old Sep 26, 2009 | 02:41 AM
xbgod's Avatar
Coil packs....... They are on the right side of the motor between the the block and the battery tray. I have nothing stock under the hood so I made lots of room for things to fit.
Old Sep 26, 2009 | 02:43 AM
CSUnited14's Avatar
man you have deep pockets must be nice
Old Sep 26, 2009 | 02:52 AM
xbgod's Avatar
bB384 I don't need to worry about the corners, I'll be 10 car links ahead of you before we hit one. While i'm watching a Movie in surround sound.
for my coil pack friend heres a pic of the packs:
Heres the ECU:
Old Sep 26, 2009 | 03:08 AM
blown_xa's Avatar
The Tial ss V-band housing is nice. Good stuff. Good to see monster builds with the 1nz-fe.
Im sure to cure our thirst for curiousity a dyno sheet or even a timeslip/video of a 1/4 mile pass would be freaking awesome. Im guessing a 112mph trap is possible with those numbers.
Old Sep 26, 2009 | 03:11 AM
xbgod's Avatar
Now heres the real trick. SEE if you can figure this one out..... Ok i'll tell you. Crank trigger hooked to a perrin pulley. I can do what ever kind of timing necessary to make more boost. Timing exciter ring is by Electomotive. Car tuned by Rolo @ CFT.
