The Fastest is here...
Old Sep 26, 2009 | 11:14 PM
  #41
xbgod's Avatar
bB384 Thanks for the greif, always need a little more in my life. Just wana say thanks to all for the positive feed back.
Old Sep 26, 2009 | 11:18 PM
  #42
coryjames's Avatar
oh and that run was at 6400 ft above sea level a general rule of thumb is you loose a second up here so that would be low 12s high 11s at sea level
Old Sep 27, 2009 | 12:22 AM
  #43
xbgod's Avatar
Thats great tool bag, You don't need to prove anything to me. I did this just for pure fun. This car is a toy not even a daily driver. Most of the stuff I build is NHRA drag racing. Prostock etc. so enjoy your XB this was a drop in the bucket for me.
Old Sep 27, 2009 | 12:32 AM
  #44
coryjames's Avatar
hey there calm down guy. We are all friend here why so full of hate? just saying lets see real world numbers some drag some track action lets see it
Old Sep 27, 2009 | 12:40 AM
  #45
xbgod's Avatar
Brother I'm not full of hate, Hell I did this just to prove it could be done. nothing more nothing less.
Old Sep 27, 2009 | 12:42 AM
  #46
coryjames's Avatar
what amount of boost are you on
Old Sep 27, 2009 | 02:16 AM
  #47
xbgod's Avatar
Look at the Dyno sheet 14psi.
Old Sep 27, 2009 | 03:14 AM
  #48
xbgod's Avatar
Kevin, about those corners... yeah if you didn't notice I have 13" front and rear disc. I can stop on a dime. I'm the only 1st Gen XB with those kinda brakes. Good luck finding rear disc with internal parking brake. The ones on my car I made at the shop over a weekend. I'll out brake any XB.
Old Sep 27, 2009 | 08:12 AM
  #49
1epoXyBox's Avatar
Great Job! Very impressive!
Old Sep 27, 2009 | 09:49 PM
  #50
Zman's Avatar
The reason xbgod's car is amazing is that it doesn't have the 2.4L of the new xB. Of course the 2.4 is a lot easier to get horsepower gains.
You two should race though...2,600 lbs against 3,300 lbs.
Old Sep 27, 2009 | 10:18 PM
  #51
coryjames's Avatar
when the new clutch goes in 450-500hp against 380-400hp i miss my first gen xb alot lighter
Old Sep 28, 2009 | 01:33 AM
  #52
Sciond's Avatar
Still wondering of Pat Barret did the trans.....
Old Sep 28, 2009 | 02:05 AM
  #53
xbgod's Avatar
At the time of my transmission build I was in Iraq working for the military. My good friend who was putting the motor back in over at Prestige Performance sent it out for me. So I'm not sure who he spoke to or worked with. Sorry dude. I just know he sent it to Level 10 and then installed the 4.3 Fidenza clutch and aluminum Flywheel.
Old Sep 28, 2009 | 09:49 AM
  #54
bB384's Avatar
IV ACE
To a certain extent you're right. Although you have way bigger brakes than my stock size stoppers, You still have full interior, lack chassis bracing, you're wheels are a bit on the heavy side and are probably bigger than 16 inches.
I have either Hawk or Axxis Ultimates, Power Slot rotors, DOT4 fluid, and stainless braided lines, my xB weighs in under 2200 lbs, is completely gutted, and I use either 16x7 5Zigen FN01R-C's (which weigh in at 13 lbs) or 15x7 Enkei RPF1's which weigh in just under 10lbs. All that less weight in the chassis, and less unsprung weight translates into much better stopping distance, and way more lateral grip at the corners.
Again I'm not trying to argue with you, Just trying to convince you to continue you're build into a track monster... I see the potential... Keep up the good work!
Old Sep 28, 2009 | 11:24 AM
  #55
xbgod's Avatar
Oh....one more thing Kevin,
12 point chromly-cage welded to sub fram, undercariage reinforced with chromoly tubeing. Axis Reverb rims (hollowed out spokes). Come on now did you think I was going to run a heavy rim. I know James Chin the owner of Axis wheels. Between the structual reinforcement and Brakes like no other, it handles like its on rails. Thank god I just don't have a bolt on strut brace and those subframe bolt-on's that someone dreamed up cause they found some holes to use underneath.
Also using steel braided lines...well because thats all I can use. And DOT 4 fluid as well. As long as the boiling point is high your fine. Did I also mention I run JIC magic Dampner system. Fully adjustable camber, double adjustable struts. Brother nothing has went undone on this car. Their is 60K invested between my self and sponsors.
Old Sep 28, 2009 | 01:13 PM
  #56
XD40tC's Avatar
I never thought Id see this from an xB1 motor... thats freakin awesome! Congrats and good work all around. You should build another one strictly for the track
Old Sep 28, 2009 | 05:47 PM
  #57
FamousxB's Avatar
i still think this one might be faster!!!!!
As we become a more automotively diverse culture you're bound to see dozens of modded Scions and JDM Nissans with Fairlady badges on one side of town, and some good old boys in their Camaros and small-block powered Novas on the other. Rick, of Whitemarsh, Maryland, has found a way to roll with both crews by dropping a stroked 350 V8 good for 450 horsepower in his 2004 Scion xB.
Old Sep 28, 2009 | 05:49 PM
  #58
FamousxB's Avatar
  #59
jct's Avatar
jct
^^^ that one is just way easier to find parts for and its cheaper too (parts wise)
Old Sep 28, 2009 | 05:51 PM
  #60
FamousxB's Avatar
to read more...http://www.cardomain.com/ride/2911003
