SQ10 and JBL p180
Old Oct 22, 2009 | 06:25 AM
Guanato's Avatar
Default SQ10 and JBL p180
Would this amp power nicely the SQ10 if wire at 360x1 @4ohms bridge? (can it be wire like that)
JBL P180.2
Output 4 Ohms90W x 2Output 2 Ohms180W x 2Output 4 Ohms Bridged360W x 1Signal-to-Noise Ratio>110Frequency Response (±3dB)10Hz - 50kHzTotal Harmonic Distortion0.05%Input Sensitivity250mV - 4V
not sure if the SQ10 (mine is the SVC) rates at 250rms or 350rms
and its late and i'm not thing straight for now
also, an amp like this should also power up some nice components rite wiring them at 4ohms 90x2
Old Oct 23, 2009 | 08:13 PM
nodsetse's Avatar
It'll be fine if your SQ10 is 4-Ohm SVC, provided you have the gain set correctly, to ensure you don't push the sub beyond it's limits. Yes, it could instead be used to drive a 4-Ohm component set (again, the gain should be set appropriately), 90w is fine for most when hi-pass filtering is used.
Old Oct 23, 2009 | 11:16 PM
rcf22's Avatar
I think the SQ-10 is rated 300Wrms max. It might be able to handle more... but that's not what it's designed for. Stick to 250-300W max.
Old Oct 23, 2009 | 11:51 PM
nodsetse's Avatar
An amp that produces more power than a speaker is rated for is safe to use, provided the system's gain is set appropriately.
torqueTc
Scion tC 1G ICE & Interior
33
May 12, 2007 02:24 PM
crabbyman
May 7, 2007 05:09 PM
McLarenF1
Jan 26, 2007 07:43 PM
ScottsdaleTC
Regional - Desert & Salt
21
Jan 26, 2007 01:03 PM
JuicyJ
21
Feb 22, 2006 06:57 PM
