Interior Water Leak Under Console - A/C??
Old Jun 12, 2005 | 10:57 PM
x_2DA_B's Avatar
Default Interior Water Leak Under Console - A/C??
Has anyone experienced water leaks from under the center console near your feet on a 2005 xB? Because mine is leaking what I am assuming is water (no smell and no taste). I was wondering if this is a common problem, or if something ridiculous happened. I read a few of the posts about condensers getting hit with rocks and broken, but none of those mentioned a water leak. Any help would be much appreciated, thanks!!
Old Jun 12, 2005 | 11:30 PM
tCinHou's Avatar
Default Re: Interior Water Leak Under Console - A/C??
but did u actually taste it???
Old Jun 12, 2005 | 11:45 PM
jct's Avatar
jct
took that phrase right out of my mind
get out of my head
Old Jun 13, 2005 | 01:43 AM
violent_b's Avatar
have you recently had a sound system installed? i.e. amplifiers? is the water on the passenger side also or just the driver side? seeing how the a/c stuff is on the passenger side of the vehicle, and if the water is only on the drivers side, I would start looking for a grommet that might not be in all the way on the firewall.
Old Jun 13, 2005 | 10:29 PM
x_2DA_B's Avatar
Yes, I did attempt to taste it, however it had no taste. The water is coming from the passenger side mostly. I called the dealer today and they informed me that it may be a clogged drain pipe that may be causing the problem. I've got to take it in to them anyways because now the A/C seems to only want to have two settings...off, or FULL, which I bet is a resistor somewhere.
Old Jun 13, 2005 | 10:31 PM
engifineer's Avatar
Most likely is the clogged or damaged drain allowing condesation to drip on the floor.
Old Sep 2, 2020 | 09:25 PM
babas3501's Avatar
my white box behind the console is leaking all over and what is it and why would it do that the drain tube is not clogged
DaBlackBox
134
Apr 10, 2022 02:04 PM
ShawnMcc
Jul 11, 2015 11:07 PM
trikkonceptz
Jun 7, 2015 01:46 AM
xb4lf
Apr 4, 2015 07:15 PM
kidkamel
22
Oct 31, 2013 08:18 PM
