Shift linkage JUMPED, nothing but 5th gear!
Old May 15, 2004 | 04:55 AM
rotarycolt's Avatar
Default Shift linkage JUMPED, nothing but 5th gear!
Today, when leaving my house... I went to shift into 2nd and my gear selector decided not to. It decided to become dislodged. It also decided that it was going to stay into 5th gear.
This freaked me out, as my xB only has 4100mi... SO I decided that it's too late to call Toyota and I wont have my car all weekend... SO, I had my buddy open the hood, as I wiggled the shifter front to back. The linkage was only slightly moving!
Took the screw out of the "rear cupholder" from under the felt, and unscrewed the shift ****, pulled the e-brake lever up and removed the snap in filler panel that resides with it. Then I popped front out of its spot and lifted the console out... to my amazement, the front to back gear linkage had JUMPED out of its holding place in the shifter base. Odd, but nothing holds it down other than 2 felt pads on the center console which is held down by plastic interior rivets.
All is well, just wanted to let everyone knows incase this ever happens to you!!!
Old May 15, 2004 | 05:04 AM
superjeer's Avatar
I smell recall
Old May 15, 2004 | 05:47 AM
bBted's Avatar
u have trd quickshifter installed???
should be easy fix...
Old May 15, 2004 | 06:18 AM
mikochu's Avatar
felt pads? the ones that are adhering to the cupholders mold? I had to rip that stuff off a little to install my leds for my cupholders...hrmmm...
Old May 15, 2004 | 06:16 PM
rotarycolt's Avatar
Nope, stock shifter. It has never been apart, either. Yesterday, to repair, was the only time the piece was ever touched.
Not really sure if the feltpads hold pressure on the cables, but from the looks of it theres nothing else that holds them down. But yes, those are the ones im talking about.
Old May 15, 2004 | 06:21 PM
rotarycolt's Avatar
Originally Posted by superjeer
I smell recall
I think they should just make a cap for them and call it a day. Wouldn't be that hard... and if they don't do it, I will.
It sucked having to take turns onto other roads @ 50 to keep from dropping the RPMS too low... which I don't suggest you do.
Probably would have been on my roof if I wasn't lowered, with 17" alloys...
Sounds dangerous, now...
Old May 15, 2004 | 06:38 PM
thats steep player congrats on making it thru that scenario. and you made to the crizo to fix the problem i smell an angel hovering some where around you
Old May 16, 2004 | 01:15 AM
rotarycolt's Avatar
Word.
Lol, just keep a phillips in the glove compartment, if it ever happens... pull over, shut the car off... and do as I said above. Had I known that was the case, I would have done it right then and there :
Old May 22, 2004 | 03:07 AM
Chris101's Avatar
Default Only 5th, broken gears
Hello to everyone. I am Chris, the new guy. I have an XB which sounds like it had the same linkage problem you have been talking about, but mine is currently in the dealership's shop with the gears torn out of it. Just wondering if anybody has heard of anything this extensive. Any info would be greatly appreciated.
evolving_machine
Oct 21, 2023 01:16 PM
ColonelSanders85
Nov 24, 2015 06:18 PM
Dmmcclair
Aug 13, 2015 07:14 PM
Brimhall_29
Jun 20, 2015 03:40 AM
annika
Mar 16, 2015 06:36 PM
