turn signals
Old Mar 14, 2006 | 05:10 AM
rs1028tc's Avatar
Default turn signals
Yo yo yo
I was wondering if there is a way to have the turn signal lights on all the time and blink when your turning left or right. I saw this on a ford work truck and it looks awesome. I just wish there was a way to do it on our cars
Old Mar 14, 2006 | 07:39 AM
Tomas's Avatar
Admin Emeritus
Should be easy enough to do with a couple of relays. Have the relays follow the flasher and connect the lights to the NC instead of the NO contacts. That should reverse it just fine.
Old Mar 14, 2006 | 11:50 PM
integsrtite's Avatar
yep but the high resistance of the relays would cause hyperblink. so (unless you want hyperblink) you'll need to get some ~1ohm high power (~21W?) resistors in parallel with the relays. http://www.v6performance.net/forums/...7&postcount=19
a friend of mine used those to do a similar thing to his 7thgen accord
Old Mar 15, 2006 | 01:23 AM
Tomas's Avatar
Admin Emeritus
Yup, it could, Alan, but it also depends on the solid state flasher circuit used, and the relay coil's resistance. If the flashing goes nuts, what you suggest is the simplest fix.
xBSciontist
Jun 18, 2019 03:06 PM
randomsuper
20
Jun 13, 2015 10:56 AM
1FasttC
Apr 9, 2015 05:05 PM
DJ_OVERGOLD
Dec 22, 2003 03:53 PM
Opr8r
Dec 11, 2003 07:35 PM
