2011-____ [ANT20]
2011+ Scion tC Bulb Sizes
Old May 7, 2011 | 08:05 PM
  #81
Scion202's Avatar
Thanks, i'll post some pics after I replace the 6 LED bulbs in the front
Old May 8, 2011 | 09:30 AM
  #82
Scion202's Avatar
Hey did anyone try these LEDs for the reverse light?
7440-x18-T: 18HP-LED 16mm Wedge Base 7440 Tower Bulb
http://www.superbrightleds.com/cgi-b...744x-x18-T.htm
They will draw roughly ~3watts, does anyone know what the fuse is rated for that supplies that electrical branch
Old May 9, 2011 | 05:10 PM
  #83
mdiluxe's Avatar
I have been watching this thread for some time. I have summed up everything about bulb sizes. Thanks to mdiluxe If I missed anything tell me..
2011 SCION TC
Low beam headlamp
H11
High beam headlamp
9005
Parking light
2827
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7443
High mount stop light
LED
License plate
168
Back up light
7440
Front sidemarker
2827
Map light
168
Dome light
175
Trunk/Cargo area
DE3022
Old May 9, 2011 | 06:05 PM
  #84
TC-Maverick's Avatar
2011 SCION TC
Low beam headlamp
H11
High beam headlamp
9005
Parking light
2827
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7443
LED
License plate
168
Back up light
7440
Front sidemarker
2827
Map light
168
Dome light
175
Trunk/Cargo area
DE3022
I've been doing work on my own (successfully swapped some lights with LEDs) and I don't understand why these number designations must be so complicated.
MOST IMPORTANT is the brake light bulbs: as the socket wiring is not compatible with regular replacements labeled "7443"; modification is required one way or another unless the bulbs are wired for CK sockets.
I understood the reason for this thread is to elaborate for the non-mechanically inclined details of the bulbs(details that cannot be read from the bulb itself like the Toyota parts tech did when I went there in person to get answers on bulb types).
I personally know that the parking lights, (sidemarker and parking are one and the same) not four bulbs for front) license plate lights and front roof lights are all compatible with 194 wedge style bulbs.
According to sources... for trunk light DE3022 must be forced in.
[I'm only speaking of replacing with led bulbs]
Old May 10, 2011 | 06:45 AM
  #85
Kriscerosaurus's Avatar
What bulbs did they use behind the HVAC dials since they didn't use LEDs? And how on earth do you get to them?
I've had a few pieces of the center console apart just out of curiosity, but even with three or four pieces loose the part by the glove box seems to be holding the HVAC cluster in. Haven't really had time to do more exploratory yanking than that.
Anyway, for those of you who have been behind there, is the orange in the temperature dial a filter that can be removed or is it a bulb thing? The orange blending with the blue/white/red is killing me.
I plan on doing some digging tomorrow. If I can figure out how to get to that one then I can work on it and the light under the letters on the gear selector. The bleh color on that bugs me as well. Aside from that, the orange dash is actually growing on me. Easy on the eyes driving home at night.
Old May 14, 2011 | 04:08 AM
  #86
Scion202's Avatar
6 vs 12 LED bulbs:
Old Jun 9, 2011 | 12:23 AM
  #87
CrispyFShacker's Avatar
Hey Guys. I was on this site back in 2005. I had a 05 Super White TC M/T. Unfortunately I totaled it in a month. Six years later and I'm back on the TC scene with a 2011 Cement TC A/T. I'm looking to do this LED swap for the interior. How do you guys think amber leds would look? I'm thinking since all are instrument panels are amber it might look good if they match. Good to be back here I love reading everyone's posts. Thanks for the help!
Old Jun 9, 2011 | 12:47 AM
  #88
Scratch's Avatar
Since you can shut off the rear dome and trunk lights, you can also just grab one set of T10 wedge bulbs for the front map lights and get a good idea of how it will look.
Old Jun 9, 2011 | 01:48 AM
  #89
Scion202's Avatar
If I were you I wouldn't get the dome lights same color as the dash. It would simply be too much. Under-dash/foot light match the dash is what looks best because u can't see the actual led strips. So dont match the lights that perform crucial functions with each other(dash/dome). Match the lights that are there for decorative reasons. My car is full of blue and initially I was gonna do the LED swap on the dash from orange to blue but realized it wouldnt be that great to have EVERYTHING the same color
If i ever want to actually do the dash led swap I'd change my dome lights to cool white leds
Old Jun 24, 2011 | 03:25 AM
  #90
rowong's Avatar
Originally Posted by johndeo11
what's the size of this light? thanks...
wait, are this the corner lights?
+1
what is the size of the bulb? is it hard to install these? thanks!
Old Jun 24, 2011 | 06:30 AM
  #91
johndeo11's Avatar
i found it... 2827=wled/194.. same size as front dome lights...
here's mine. just installed last night. not that hard. as they said, how to remove them lights in on our manual.
Old Jun 24, 2011 | 01:47 PM
  #92
jtk2's Avatar
to get the the hvac controls. theres like 4 or 5 pieces that need to be pulled out. just work your way around it. and it all just pulls out. when you geet into the controls. theres 2 lights. ones an led which is that orange light you see when you turn the ac button on. and the other one is a twist bulb. something like this..
and the ones in the gear shifter are a 74.
Old Jun 24, 2011 | 01:56 PM
  #93
WellesleyScion's Avatar
Any idea on what size bulb the hvac ones are?
Old Jun 24, 2011 | 02:13 PM
  #94
jtk2's Avatar
all i know is its the smaller one of those 3 ^^. which is a 3mm. you can find them at superbrightleds.com
Old Jun 25, 2011 | 02:31 PM
  #95
rowong's Avatar
Thanks!
how many LEDs bulb did you use and where did you order them from?
Old Jun 25, 2011 | 07:23 PM
  #96
johndeo11's Avatar
superbrightleds.com i just use one bulb sir...
Old Jun 25, 2011 | 08:03 PM
  #97
rowong's Avatar
Ohh, I meant, how many LEDs were on that one bulb.
Is it the bulbs found here: http://www.superbrightleds.com/cgi-b...%2F921-x12.htm
Thanks!
Old Jun 25, 2011 | 08:34 PM
  #98
johndeo11's Avatar
i used this sir. http://www.superbrightleds.com/cgi-b...s%2FWLED-x.htm
but i think that'll work...
1 LED sir...
Old Jul 4, 2011 | 09:48 AM
  #99
Scion202's Avatar
1 LED sir...
cool white or blue?
Old Jul 4, 2011 | 09:49 AM
  #100
Scion202's Avatar
here is a small guide for T10 LEDs for the car and their uses
