not shifting into overdrive
I have a 2005 xb automatic. I have noticed that quite often the transmission will stay in 3rd and not shift into overdrive even at rpms close to redline. I can left off the gas and slow down and the only thing that gets it to shift when it hangs is turning the OD off and back on really quick. anyone else have this problem with their automatics??? Also, it isn't fluid cause I check it often.
Originally Posted by 150dBxB
ive had the same problem, its time to chaange your tranny fluid
you should be doing it every 15K
once you do it it shifts like BUTTA
I can make it happen if I go up a slight hill while applying the power...at the top of the rise, as long as the power is still applied it doesn't shift up. I'll look at the RPM's tomorrow and see where it is hovering while doing this.
If it is the tranny, I will return the car real quick and get my money back. 6000 miles is way too soon to even think of a tranny problem.
Andy
Look at your dash when this happens. Is there a blue light? Did you just start your car? The autos are programmed to not get into O/D while the engine is cold, which is what the blue light signals. It won't get into third when it's really cold. In winter you must let the car warm up a bit.
In the Scion literature the holding of the vehicle in gear, and not allowing upshifts until the speed/throttle position are more closely aligned with what the ECU expects is a DESIGNED IN FEATURE - it's SUPPOSED to work that way.
From one of their many descriptions:
Uphill Shift Logic (“Grade Logic”)
1. ECM can determine when climbing a hill by comparing the actual acceleration rate with the acceleration rate predicted based on throttle angle.
2. upshifts can be inhibited when lifting the throttle for a curve; this keeps the engine rpm in the peak torque band and provides a smoother ascent.
So long as the actual acceleration/speed is less than predicted by throttle position (hill climbing, high load, max throttle acceleration, etc.), the 'Grade Logic' program built into the vehicle's computer will inhibit upshifts.
Returning to a more normal operating environment allows it to reset.
(It also watches steering input to prevent shifts at bad times while cornering.)
(The comment about 'blue light' in the instrument cluster is right on, too - it will prevent shifts into overdrive until the engine is sufficiently warmed up for the 'puter to be happy.)
This is a computer controlled drivetrain - it has a WHOLE lot more tricks built in than the old Chevy V8's with Powerglide did... :D
Another thing to do would be to look up info on the generic Toyota ECT - information a lot like ECT.pdf (580K), whick will explain a lot about how the ECT thinks and why...
The auto trans in the xA/xB is a fairly sophisticated unit with a lot of variables it look at to determinw what to do.
It also has a lot of very good features, including lockup on the top two gears for improved economy, etc.
My understanding is that, at least in the xB, the ECT and ECM learn together from their experience with the driver's driving style, and set themselves up to match that style - including even higher shift points for those who drive aggressively - to improve performance, and lower shift points for those who drive conservatively - to increase MPG.
(I think mine is probably confused cause I sort of alternate back and forth. Maybe I should reset everything and try 'conservative' mode to see what that does for mileage...)
When you say "Scion literature" what exactly are you refering to? I'll check the owners manual in the morning, but I suspect what you quoted is from a tech manual.
FYI. I understand the "blue light" delay in shift points. I experience this shift retarding when the xA is well warmed up and going up a grade on a curve at 45 mph. Actually feels kinda nice to have the engine "pulling" me up the grade.
Thanks,
Andy
well before i contacted the dealer i wanted to see if anyone else was having that problem. i don't think it is the tranny fluid since i only have 5400 miles on it. so when i go in for my oil change in a month i will have them put it on the computer
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
