OIL FILTER BASICS
Old Mar 6, 2006 | 11:47 PM
  #61
SciontCya's Avatar
Big Sky Scion
Originally Posted by NVFirefighter
Can anyone tell me the difference between the stock OEM filter and the TRD filter?
Thanks
The TRD supposedly has a different screen and has a synthetic filter layer as opposed to the paper of the stocker.
I've read a lot on this, and decided the extra money was not worth it.
It's likely a higher-flowing filter, with possibly less filtering for smaller particulate - which is good for racing.
Stick with the OEM for less than half the price.
Scott
Old Mar 7, 2006 | 07:19 AM
  #62
jmitch8011's Avatar
thanks slboettcher for that info.
Old Mar 7, 2006 | 05:26 PM
  #63
NVFirefighter's Avatar
^^^^^ Thanks for the info.....
Old Mar 7, 2006 | 05:46 PM
  #64
SciontCya's Avatar
Big Sky Scion
Glad to help...
My mechanic also told me this weekend that the tC filter from Toyota is about 1-inch longer (taller) than other SCIONs and other makers of some tC filters. they cut it open to see if it was different in other ways, and found nothing of note. It likely has more oil in there for startups - that's our guess anyways.
Stick with OEM filters, and get a good oil. I'm using M1 (Mobil1)
Scott
Old Mar 11, 2006 | 01:38 AM
  #65
Carnauba's Avatar
Default filter choice
I just got my xb and it is almost time for oil change. Every one says use only toyota filter? I have a 83 toyota pickup with 211,000 miles on it and it hasen't had a toyota filter on it since the factory one came off for the first oil change 23 years ago and it runs like a new one. Oh did I mention it was a farm truck for its first 18 years and has had a very rough life. So will my xb live if I don't use a toyota filter?
Old Mar 11, 2006 | 02:05 AM
  #66
SciontCya's Avatar
Big Sky Scion
^ It will live well and long, all things being equal. Toyo filters are highly regarded...
Scott
Old Sep 3, 2006 | 06:22 PM
  #67
moturley's Avatar
Default Oil filter study
Check it out if it has not been posted already.
http://minimopar.knizefamily.net/oilfilterstudy.html
Old Sep 12, 2006 | 11:41 AM
  #68
raWr215's Avatar
about the "initial oil change" for new cars, this applies to mostly older cars. From what the dealer said, our cars have already gone through the break in period, our responsibility is not to push it as indicated in the manual for the first X number of miles.
maybe this is why there are no metal debris found in the filter in the first oil change.
good job on the information post on filters
Old Feb 8, 2007 | 07:53 PM
  #69
nlombardi1's Avatar
I've been searching and searching. What is the size I need for the K&N oil filter?? I want the K&N oil filter sooo bad. Please help I have a '07 tC.
Old Feb 8, 2007 | 08:38 PM
  #70
SciontCya's Avatar
Big Sky Scion
Why?
You can buy what you like, but the Toyota filters are outstanding.
Why waste money?
That's the conclusion for K&N oil filters, FWIW.
Get the Toyota YZZF1 from TRDSPARKS.COM - 10-paks for ~$35.
If you've been reading, you'll save some trouble and money by not using K&N.
Scott
Old Feb 9, 2007 | 04:04 AM
  #71
nlombardi1's Avatar
Why?
Why waste money?
Scott
how many microns do the toyota filters trap??
If anyone wants to know the size for the K&N oil filter is HP-1003 got mine at AutoZone for $8.00!!!
Old Feb 9, 2007 | 04:38 PM
  #72
SciontCya's Avatar
Big Sky Scion
Microns filtered is only 1/2 of the filter equation.
Flow is as important if not more-so.
You're all entitled to use the filters of your choosing, just don't waste money on what you think is a better solution.
It not only may be less effective, but more expensive as well.
Do the research - you might be changing your mind.
Old Feb 9, 2007 | 08:59 PM
  #73
Tomas's Avatar
Admin Emeritus
Just off the top of my head, and I suspect that the info could be researched on-line, I cannot believe that there are ANY clearances in ANY current automobile engines that are even approaching less than 30 microns.
In my mind, that means that a filter that does not pass particulates larger than 15 microns will protect current engines more than adequately.
Filters that try to filter even smaller particles are simply putting unnecessary restriction into the flow of lubrication.
I would much rather have adequate flow with some particles less than half the thickness of the lubricant film included, than have inadequate flow just to get the particles down to one quarter the size needed to do any damage...
Tom
Old Mar 6, 2007 | 07:22 PM
  #74
ayS's Avatar
ayS
on trdsparks.com they have the s/n for the filter which is different then posted. have they changed part number recently or is this a newer updated filter? i want to know in case i put in the wrong one. hehe..
Old Mar 6, 2007 | 07:29 PM
  #75
kanundrum's Avatar
Ah so its best to stick with stock toyota filters then shelling our more for the trd and K&N filters ?
Old Mar 6, 2007 | 07:30 PM
  #76
SciontCya's Avatar
Big Sky Scion
Old Mar 6, 2007 | 07:31 PM
  #77
kanundrum's Avatar
But If i did want something a little better I would go with Mobil1 or its still not worth it ?
Old Mar 6, 2007 | 08:02 PM
  #78
SciontCya's Avatar
Big Sky Scion
Better?
Who says they're better?
Mobil1 marketers?
Data?
Save your money for good oil and stick with the YZZF1s.
Your tC will be happy.
Old Mar 6, 2007 | 08:06 PM
  #79
kanundrum's Avatar
Will dooo thanks for the data and the good info.
Old Mar 6, 2007 | 08:51 PM
  #80
SciontCya's Avatar
Big Sky Scion
Seriously.
It's what I use and I'm 100% **** about my car and maintaining it.
I've done a lot of research, and the one thing I feel good about is Toyo OEM filters.
I use synth oil and that's all you need. (not saying you NEED synth, it's my choice)
Drive on!
