Problem at the Gas pump
Old Jan 18, 2005 | 05:03 AM
  #101
Xbilly's Avatar
I'm glad I don't have this problem, I think it may have happened two or three times but im sure it was the pump at fault. not as bad as my CRX sometimes tricked some pumps into overfilling my the tank until the gas sprayed out all over the place. talk about lookin like a retard
Old Jan 18, 2005 | 12:46 PM
  #102
FrankenScion's Avatar
It doesn't really work like that. If you don't have an xB, you probally won't get. Its just a screwed up design that I'm gonna get fixed.
Old Feb 15, 2005 | 10:07 PM
  #103
InfoDiva's Avatar
Glad to find this thread, thought I was moron with new tC and just had forgotten how to pump gas or something retatted like that. Will try the suggestions listed here in the hope that I won't have to have the tank and neck replaced!
Old Feb 21, 2005 | 11:21 AM
  #104
FrostedTheFlake's Avatar
Originally Posted by showpaojoe
It's certain gas stations.
For me, that's the case. Shell stations that have the older pumps give problems. So does Citgo. Never had probs at Chevron, 76, or Texaco. I refuse to use ARCO for quality reasons, and refuse to use Exxon or Mobil since they're more evil than other oil companies.
Anyway, my friend was able to help me pump at Citgo (he was like "just put it in more" and then made it work). So I thought i was just clueless. Glad to see this problem is beyond just me.
Old Feb 21, 2005 | 01:04 PM
  #105
PaganGuy's Avatar
I just had the TSB for the gas tank done and it does fill so much better! Which is good in the middle of winter. But i have noticed a big drop in mpg. First tank full after the TSB went down to 22 mpg. Has anyone else had this issue? 22 seems damn low for such a new vehicle.
Old Feb 21, 2005 | 01:22 PM
  #106
I did not notice any cahnge in MPG when they did mine. I'm not even sure haow that would be possible.
Old Feb 21, 2005 | 06:31 PM
  #107
engifineer's Avatar
The only way i could see this affecting mileage was if it affected the vent system.. and even then I am not sure of that effecting it. If it did affect the vent though, it should turn on the Malfunction light.
My mileage from day one with the tC was about 29 on the highway and about 20 in town. Not very good for a new 4 cylinder... but it does move quickly so I'll take the lower mileage :-)
Old Feb 21, 2005 | 06:43 PM
  #108
cameracar's Avatar
Although you'll still need to stand at the pump (the law in most states anyway), you can pull the nozzle back about half way to the point the air holes are just inside the restrictor door and pump at full speed. It's not like we are filling a 40 gallon tank for 10 minutes just about 45 seconds to a minute from empty.
Old Feb 21, 2005 | 11:13 PM
  #109
shangtsung's Avatar
What quality reasons?
Old Feb 21, 2005 | 11:24 PM
  #110
Every other car I've filled with ARCO seems to run poorly on it. Some people say "gas is gas," but some just seems different with ARCO
Old Feb 22, 2005 | 05:52 PM
  #111
bahamut_zero's Avatar
I just stand there anyway and pump it while holding the handle. I never learned any differently. Doesn't take too long at all, and I like to be active in ALL parts and going on's concerning my tC, including pumping. I like pumping.
Old Feb 24, 2005 | 08:45 PM
  #112
big_c's Avatar
OhioScions
I just got my gas tank replaced by Scion free of charge. It did the trick.
Old Feb 25, 2005 | 01:08 AM
  #113
xAlex's Avatar
could this be done at any dealer? or do u have to go where you bought the car?
Old Feb 25, 2005 | 01:15 AM
  #114
any toyota dealer
Old Mar 9, 2005 | 08:45 PM
  #115
Max's Avatar
Max
Just got it done, huge difference, nice to be able to let go of the handle. No idea on mileage thusfar.
Old Mar 9, 2005 | 09:23 PM
  #116
Amazing, isn't it?
Old Mar 13, 2005 | 08:32 AM
  #117
hnefrdo's Avatar
OKAY! I have the gas pumping problem with my xA and it looks like my car falls under this "TSB."
What's a TSB?
Old Mar 13, 2005 | 08:37 AM
  #118
JdMBboFSD's Avatar
...its the gas station ....switched....no probs now..
Old Mar 13, 2005 | 10:28 AM
  #119
scionscorpion's Avatar
i am kinda use to it with my gas tank .........ok here is what i do ? ....... i dont put the whole thingy into my gas tank ......because then that problem accures ...........so put it like half way in and squeez the gas as much as u can and it wont stop ............
Old Mar 13, 2005 | 11:46 AM
  #120
Digital_Infiniti's Avatar
Default Solution
Take your gas cap and stick it sideways into the handle area. It's a stupid way to do it, but it works.
