Spark Plug Boot not bolted down
Old Feb 9, 2013 | 10:11 PM
Barrykinz's Avatar
Default Spark Plug Boot not bolted down
So I was having some issues with a rough idle and the engine was misfiring in cylinder 2 and 4. I'm assuming it was about 70,000 miles since the Spark Plugs have been changed. The previous owner would've been the one to do them.
Well it fixed my rough idle and engine misfiring.
The problem is though when I was taking the boots out I noticed one Coil On Plug wasn't bolted down and the bolt broken off inside the hole. Will this COP not being bolted down cause a huge issue?
(Not sure if this should be in Maintenance and Car Care or not.)
Old Mar 30, 2013 | 06:26 PM
TigerDude's Avatar
considering it's what holds the "boot" on the plug, seems like it could be a problem. You're just relying on the rubber to hold it on.
I must point out to you young bucks what a great system this is - we used to have to replace plug wires because the high voltage wore them out. And I won't even start on timing & points!
kleecker
Jul 11, 2015 09:39 PM
my06tc
Jun 25, 2015 12:18 AM
tCSpdRacer
May 2, 2015 03:33 PM
daniinpitt
Apr 4, 2015 08:07 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
