Tire Care
I have put together a little test that we have done since we get many requests regarding our tire gel.
Tire Gel
Here’s an example of the difference between a good tire care gel and the average product that some of you use.
This time the test mule is our 85ft rig.
Condition of tire after driving 900 miles, dull and dirty, one particular tire had been previously protected with a well known brand.
Tire Preparation
First Step following some simple directions using our Tire and Wheel Brightener
Spray onto a cool wheel, let set for about one minute, and then agitate with a sponge or soft brush to activate the formula for even better cleaning. Rinse thoroughly. For heavily soiled wheels, process may need to be repeated.
Turbo Wax Wheel Cleaner and Brightener is unique in that it actually cleans the wheels without acids or other harmful chemicals, some of which can and will cause spotting or peeling of the clear coat on the wheels. Works well on plastic wheel coverings as well. If accidentally sprayed onto vehicle finish, just wash off, no harm done. Product is also pH-balanced and formula will not stain clear coats.
Turbo Wax Tire and Wheel Brightener sprayed on Tire and Wheels
The following tire was protected with a well known brand of tire shine, all the gloss was gone on both of the products ours and them, however after our tire and wheel cleaner product had settle I took the following picture, you can clearly see all the chemicals residue coming to the surface, on the second picture you don’t see the same effect since that tire was previously protected with our tire gel.
Leading brand
Ours
Tires after been wash
The tires were protected with our Tire Gel, 2 coats were applied for a deep shine.
250 Miles later
700 Miles later
900 Miles later
And the same on all other tires, and no SLING!!!!!
Just in case we did put together a forum sale, the thread is here.
https://www.scionlife.com/forums/viewtopic.php?t=193820
thanks for looking
Tire Gel
Tire Preparation
Leading brand
Ours
250 Miles later
700 Miles later
900 Miles later
thanks for looking
See my review I highly recomend this product!
https://www.scionlife.com/forums/viewtopic.php?t=195280
Originally Posted by prboyxb
Interesting
"For me, I was most impressed with the tire shine. I used it 3 weeks ago, an its still on there. And best of all, when I drive it doesnt come off the wheel and plaster the side skirts like most tire shine does. And everyone with a light color car knows that all the other products make a mess"
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
mischadoll
Mar 9, 2015 05:48 AM
ScionVan
11
Dec 2, 2003 09:37 PM
