Fixing Turn Signal LED Help!
Old Jul 16, 2006 | 04:46 AM
TeeCizzle's Avatar
Default Fixing Turn Signal LED Help!
OK, Since I am new to the LED game...I got LED turn signals and I dont think I like the Hyper Flashing...So on this link be low which item do I need to get it back to OEM flashing standards??.....Thanks!!
http://autolumination.com/equalizers.htm
One More Question...I also got the 12 LED 7443 bulbs..I dont like them they arnt bright enough...Then I heard them tower LED lights dont fit correctly...What do you people suggust for the 7443 LED's???
Old Jul 16, 2006 | 06:28 AM
SquallLHeart's Avatar
get any of those load equalizers...
and i would keep the stock incandesant 7440's and 7443's
led "bulbs" for turns and taillight stuff just aren't good.
you would need to actually retrofit and build something yourself to make something bright enough.
Old Jul 16, 2006 | 06:35 AM
TeeCizzle's Avatar
So you dont recommend at all in using LED bulbs then??.....and Why?..jus curious!
If I do get the Equalizer thing..I need 2 of them??....
Old Jul 16, 2006 | 06:44 AM
one load equalizer for each bulb.
https://www.scionlife.com/forums/vie....php?p=1700970
read up on comments.
Old Jul 16, 2006 | 02:51 PM
FaulknerScion's Avatar
if you put in leds. can you just plug and play? or do you need to get resistors or something?
Old Jul 16, 2006 | 07:04 PM
replacement led "bulbs" have resistors built in.. it's plug and play.... but the lighting will suck. that's why i don't recommend them
unless it's like your dome lights, and license plate lights.. parking lights (if they can withstand the heat).. cubby hole light.. etc..
turnsignals, taillights stuff?... no.
Old Jul 16, 2006 | 07:08 PM
Hyghgynx's Avatar
You could just 'plug n play', but then you get the hyper 'ricer-civic' look. Hence why he needs load equilizers. BTW-You'll need some for the tails if you swap those out also.
Old Jul 16, 2006 | 07:18 PM
just blinks fast? but wont burn out any wiring right?
Old Jul 16, 2006 | 07:54 PM
no
Old Jul 16, 2006 | 08:58 PM
TeeCizzle's Avatar
Ok, I just put back the good ol Halogen bulbs back in took the LED's out...*sad* too bad, I wanted the cool G35 look...I dont have the skills of doing a Retrofit thingy..
xBSciontist
Jun 18, 2019 03:06 PM
randomsuper
20
Jun 13, 2015 10:56 AM
Opr8r
20
Feb 25, 2004 11:29 PM
DJ_OVERGOLD
Dec 22, 2003 03:53 PM
Opr8r
Dec 11, 2003 07:35 PM
