Headlights
yep, ive done it, like he said, remove as much of the old silicone as possible and re-aplyit correctly, you should be fine
since were on the topic of headlights, wats the best silicone/sealant to use???
Don't be so quick to remove the old stuff. What are you guys using to reseal the headlights? If you use silicone then how are you going to open them again if you need open them for any reason? The factory sealant is great because it is heat-activated. You can usually get away with opening each headlight 2 or 3 times and resealing with the remaining factory sealant.
no, i dindnt mean remove the factory sealant, i meant remove the old silicone he used the first time it was opened, once u sandwich them together, then use new silicone around the light. and as for opening them with silicone on them, its easy silicone will peel right away, i used a small flat and a blade to remove as much as i could then proceded to open the headlight
but yeah i heard something people call "nissan stuff" to seal headlights, what is it, and where can it be bought?
Yeah I found it on an Acura website. It seems that you can shape it and mold it any way you want, like putty or something. It's heat-activated, so it should behave the same way as the factory sealant on our headlights.
vi3tb0i09
Sep 23, 2015 08:32 PM
atlantaemail
Sep 20, 2015 02:03 AM
