HID Help
Old Feb 29, 2008 | 12:25 AM
BZinn1's Avatar
Mobil HID or operatic for quality kits.........6000k for slightly blue.........8000k is blue...........no ebay or cheap..........you will end up with junk........do it right the first time...........or pay twice to fix it.
Old Feb 29, 2008 | 02:02 AM
striker_1818's Avatar
funny all aftermarket kits are the same quality.
and the little "do it right the first time" advice goes for actual quality components such as oem vehicles that test and retest their products and outlast the vehicle itself.
if you want to do it right the first time, go with a retrofit. if you want to cheap out and get a narrowed beam halogens even outporfm, then get an hid kit. But if you indeed get an hid kit, do not forget to aim your headlights lower than usual. otherwise you may ____ off the wrong driver at the wrong place and tim and get your butt kicked or harrassed.
Old Feb 29, 2008 | 02:30 AM
20tCDude05's Avatar
^^^ Thanks man, gonna go with 6000K. I just hope it is what I want.
Old Feb 29, 2008 | 02:39 AM
20tCDude05's Avatar
Sorry, I meant the person before the one before me.
Old Feb 29, 2008 | 02:45 AM
BZinn1's Avatar
You are absolutely right with that point.......but.........the poster is asking about quality kits.........and has no ability to do a retrofit.......in his own words..........to be quite honest the 08 projector does a great job of putting out the light..........yes it has hot spots in the middle,but the output is much better than halogen...........and a good kit will last much better than cheap ebay junk..........
I wil be doing a retro on my 08s soon since they are leaking inside stock and I jsut got my warrenty lights........so I got a free set to work with.........and even found a set of projectors from a Saab in the junk yard for cheap.............well if $300 is cheap........
Old Feb 29, 2008 | 03:20 AM
20tCDude05's Avatar
Ok, I am going with 6000K HIDs from Mobile HIDs, but there are different kinds. What kinds do I get for high beams and low beams?
Old Feb 29, 2008 | 08:09 PM
20tCDude05's Avatar
Anyone?
Old Feb 29, 2008 | 08:11 PM
SicktC06's Avatar
Default Re: HID Help
Originally Posted by SicktC06
Originally Posted by 20tCDude05
I am looking to get some 8000K HID bulbs. I want them for the regular and bright lights. So, what brands are good? I am thinking Hella is one of them. I want a very crisp platinum colored light like the really nice cars like BMW, Lexus, etc come with. Like with a small blue tint to it. Anyone help me on this?
Ok here we go.
....Your Headlights are 9006 for the low beams and 9005 for the highbeams. McCollah (sp?) is a good brand but really pricey. do a search and you will find MANY HID threads out on this site. Type in the search box "HID&Headlights" and I promise you that you should find something there of use.
Old Feb 29, 2008 | 08:14 PM
oh the saab projectors are the same as the non-afs rx330 projectors. if you know how to mod them, then you will get a wide and very intense output. If you don't, then output will be miserable.
With the non-afs you will get from the saab, you need to make a shield. Also, you need swap lenses if yours come with riddles or rings on it.
Old Feb 29, 2008 | 08:30 PM
firesquare's Avatar
you don't want high beam HID's unless your getting a Bi-Xenon which are pretty expensive. stick with a halogen high beam to keep viability at its best and you wont burn out a ballast by using it off and on since it takes time for a HID system to "spool up"
if you do turn a HID system (ie: high beam application you will prematurely burn out the ballast which cost more then the bulb.
i have 5000K which is really good. for me anyways. it doesn't look all ricer blue and it works great in the fog. 4300K is "Factory style" HID.
Old Mar 6, 2008 | 04:32 AM
pinoyFMtC's Avatar
I ran the mobileHID kit for a little while 6000k, and its a good quality kit. But even with aiming them down I thought it had too much glare and I was getting flashed a lot, so I took them off...
Old Mar 6, 2008 | 04:53 AM
20tCDude05's Avatar
Aight, I will go with 6000K Mobile HID when I get it.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
