HID Help
Old Feb 17, 2010 | 03:12 AM
getaforknjob's Avatar
Default HID Help
So over the past couple weeks my drivers side HID bulb has been flickering whenever I would turn on my car and when ever I would go over big bumps.
So today before I went to go to ship some items, I went to turn my lights on, and as usual the drivers side began to flicker, so I turned off the lights and then attempted to turn them back on..although the drivers side would not turn back on this time.
So I went to check it out and I found that the two plugs that connect the HIDs to the harness were both corroded and one of the prongs from inside the HID connect had fallen off and was now stuck inside the spot it slides into in the harness connector.
I tried to pull the prong out although it is really stuck in there.
So the only other thing I could think of doing was to start splicing wires together.
I continued to splice and finished up with what I thought was the correct solution.
Now it won't turn on at all.
I then checked the fuses for the headlight low beams and they were both good.
I need some assistance here.
Old Feb 17, 2010 | 03:15 AM
FlintMica2005's Avatar
happened to me with my first set of HIDs when i b ought my car in 05. it was the ballast that was shot. i changed the ballast and kept the bulb and voila! its been working ever since for 5 yrs now
Old Feb 17, 2010 | 04:18 AM
Damn. Lol.
So your saying...even with how I spliced the wires together like how I stated, it should still work if I replace the ballast?
Old Feb 17, 2010 | 10:52 AM
Leadfootlarry6's Avatar
United Imports
Did you hook the wires up the right way? If they are back wards they will not turn on. just asking, I have seen them not work if not hooked up right. the other thing is get a relay harness that hooks to the battery and then just use some butt connectors instead of the plugs. the only plug you would use is the driver side head light to turn on the system..
Old Feb 17, 2010 | 12:13 PM
idk now since u spliced the wires bro lol but def was the ballast. I say just get a complete new set but if not just buy ballasts first and see if the bulbs will work, if not get new bulbs. ebay has them for cheap
Old Feb 17, 2010 | 01:04 PM
CarbonXe's Avatar
Cheap bulbs FTL.
Old Feb 17, 2010 | 01:14 PM
Yes I did splice the wires correctly..I even reversed them to see if it would work and it didn't.
I'm buying new male and female plugs for the drivers side..and then buying a new ballast today hopefully and we'll hope that's the issue.
The bulb should be fine..I looked at that too, and it didn't look burnt out or blown inside.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
