Please Help!! How to Pop the cover for License Plate Light
Old Dec 19, 2006 | 09:13 PM
gomdangie's Avatar
Default Please Help!! How to Pop the cover for License Plate Light
I feel stupid...
I have problem poping out the cover for the license plate light
I tried to search but couldn't and I gave a go, but i got some scratches...
..............______1_______.................
(outer)2|........................... | 3 (inner)
...............______________..................
..........................4.................................
say this drawing is the left side of the cover
1 and 4 doesnt seem like flat screw driver fits
let me know so that i can do this tonight......
thanks!
Old Dec 19, 2006 | 09:17 PM
SquallLHeart's Avatar
....... you know you access it from inside the car right?
and.... it's in the manual.
Old Dec 19, 2006 | 09:27 PM
Neothin's Avatar
and all you need is a flathead scredriver
gomdangie's Avatar
ah really...?
ok thanks a lot..
i feel even more stupid now
Old Dec 19, 2006 | 09:38 PM
Hyghgynx's Avatar
^^Just pop off the covers on the hatchback with a flathead screwdriver, twist out the socket(s), replace bulb(s), put back and twist back in. Shouldn't take you longer than 2 minutes, tops.
*Brouse through your manual. You will end up with a lot LESS scratches.
Old Dec 19, 2006 | 11:54 PM
s44life's Avatar
I just got my new led license plate lights and I got the panel off without a problem but I couldn't get the damn lights out. Those _____es are in there tight, I'm gonna try the pliers tomorrow......I'll try not to brake them
Old Dec 20, 2006 | 12:02 AM
Gortok's Avatar
The sockets get slightly melted due to heat from the original bulbs. They are a PITA to get out, pliers ARE necessary.
You'll probably have to bend the socket connectors a little to make them tight on the new bulbs also...if they aren't tight they'll flicker on and off with road vibrations...
BTW, you'll the LED plate lights...
Old Dec 20, 2006 | 01:37 AM
^^ only in some cases are they on tight...
i was able to twist them out by hand fine. so pliers AREN'T necessary
Old Dec 20, 2006 | 01:39 AM
Neothin's Avatar
make sure your turning the right way..
righty tighty, lefty loosey
Old Dec 20, 2006 | 02:52 AM
fflores's Avatar
yes... the manual... suprisingly to some is a vast welth of knowledge...
it took me longer to find the page in the manual on the LP lights then it took to do the swap...
I did have to use pliers for to twist the harness out of the socket, and to remove the bulb from the fixture
Old Dec 20, 2006 | 06:56 AM
ADRdesignCo's Avatar
dont forget to wrap thhe bulb with a cloth so you wont scratch it when you turn it... its a PITA the first time you take it out.. but after that itll come out easier
Old Dec 20, 2006 | 11:01 PM
gomdangie's Avatar
thanks guys, my new license plate light looks awsome
Old Dec 22, 2006 | 05:12 PM
StevieSoFly's Avatar
did you have trouble taking taking the light/harness out? cuz mine was pretty tight. im gonna do it later when it warms up.. im lazy. you should post pics of it
Old Dec 22, 2006 | 05:31 PM
some people have trouble... some don't..
for people that have trouble... they used needle-nose pliers.
Old Dec 23, 2006 | 02:08 AM
gomdangie's Avatar
hm i didnt really have troubles after i found out u work from inside...
u just have to turn left to take hardness out and u pull straight to take out bulbs.
horsefeathers
Sep 17, 2023 11:12 PM
Ferretgrrl
Oct 15, 2018 02:50 AM
anti_virus347
May 28, 2015 06:01 AM
gyiu
Regional - Pacific South
12
Feb 20, 2015 04:20 PM
BlueBox
Sep 30, 2003 11:18 PM
