Spyder Halo/LEDs - LOW beams not working
2008 tC - After installing new Spyder headlights, all lights (DRL, blinkers, high beams) work, however the low beams don’t.
Fuses and relay looked good. Replaced both bulbs, also replaced headlight dimmer switch on steering column to no avail.
Any suggestions would be much appreciated.
___
___
2008 tC - After installing new spyder headlights, all lights (DRL, blinkers, high beams) work, however the low beams don’t. Fuses and relay looked good. Replaced both bulbs, also replaced headlight dimmer switch on steering column to no avail. Any suggestions would be much appreciated
