2006 Scion tC won’t crank or start,
Old 11-18-2017, 10:27 PM
Orzaldivar's Avatar
Default 2006 Scion tC won’t crank or start,
My Scion tC wont start or crank i have try everything and nothing work. Change the relays fuses but nothing,
all the lights on the dashboard work battery is good, starter is good too bad nothing happens when i try to start the car
Last edited by MR_LUV; 11-28-2017 at 11:08 AM. Reason: moved to Correct Forum by Moderator
Orzaldivar is offline
Old 11-19-2017, 06:45 PM
xile6's Avatar
Start with this.
check the battery voltage 12v or higher?
when putting the key in does the Security Light go from flashing to off?
when cranking it do you hear the motor spinning?
xile6 is offline
Old 11-27-2017, 10:25 PM
Orzaldivar's Avatar
Default Thanks
Originally Posted by xile6
Start with this.
Thanks i got it to work , the ignition switch was bad. But i also have a electrical problem, i keep working on it to find out what it is
Old 12-11-2018, 12:21 PM
Jay_Ramirez2120's Avatar
I dont know if you found out but theres a small quantity of fuses behind the obd2 port , i had a similar issue , turns out some fuses there will prevent car from turning on or staying on for that matter , i used a tester to verify both sides of the fuse had current and found 2 that had gone out .
Jay_Ramirez2120 is offline
revalina
12
12-27-2022 04:21 AM
randolph09
18
02-13-2019 05:19 PM
EmanBass
08-09-2014 01:28 PM
joshstiles4
06-11-2011 06:16 PM
DSMing91
13
02-10-2008 02:57 PM
Quick Reply: 2006 Scion tC won’t crank or start,
