My car won't start at all..
Old Jul 23, 2011 | 11:50 PM
randolph09's Avatar
Default My car won't start at all..
My 2006 Toyota Scion xA won't start at all. I tired jumping it and it didn't work. So we charged the battery and then tired it again and it still won't start.
The head lights come on and that's all. So I don't know why it won't start. Dose anyone have an idea of what might be wrong with it and why it won't start
Old Jul 24, 2011 | 12:00 AM
Jon's Avatar
Jon
Moderator
Moderator
Bad starter? Does it try and turn over at all?
Old Jul 24, 2011 | 12:08 AM
randolph09's Avatar
no it won't even turn over at all. The head lights are the only power the car has.
Old Jul 24, 2011 | 12:17 AM
randolph09's Avatar
Arrow
nope it won't turn over at all either
Old Jul 24, 2011 | 01:36 AM
ajdaly12's Avatar
not the steering wheel lock right?
Old Jul 24, 2011 | 01:44 AM
randolph09's Avatar
nope my steering wheel isn't locked right.
Old Jul 24, 2011 | 04:33 AM
jbae1221's Avatar
So you don't have any dash lights? Prolly bad starter
Old Jul 24, 2011 | 06:13 AM
Jon's Avatar
Jon
Moderator
Moderator
I would start with fuses, make sure none are blown. If they aren't then it's probably the starter.
Old Jul 24, 2011 | 01:04 PM
randolph09's Avatar
ok I will do that
Old Jul 24, 2011 | 06:04 PM
Reactor's Avatar
Get a test light and see if the starter solenoid is receiving a signal at all.
Old Jul 24, 2011 | 06:45 PM
Vlad1024's Avatar
If nothing else turns(radio/accys) on it is probably a fuse, bad wiring, or the ignition switch.
Old Jul 24, 2011 | 06:51 PM
randolph09's Avatar
ok so what if I fixed the fuse and the car starts but out let me shift to it out of park. Also my ac,radio and dashbroad lights won't come on and the fueses aren't blown
Old Jul 24, 2011 | 06:54 PM
Vlad1024's Avatar
the common factor here seems to be the ignition switch and related wiring. once again check fuses and relays.
Old Jul 24, 2011 | 06:56 PM
randolph09's Avatar
ok so what I fixed the fuse and the car now starts but won't let me shift out of park. Also the radio,ac and dash broad head lights don't turn on and the fueses are all good
Old Jul 24, 2011 | 06:57 PM
Jon's Avatar
Jon
Moderator
Moderator
Have someone stand behind the car while you press the brake. If the lights don't work then the stop fuse is blown which is why it won't let you shift out of park.
Old Jul 24, 2011 | 07:00 PM
usafscion's Avatar
I know this might sound stupid but is it AT / or manual..
I had a similar problem and it was my clutch pedal switch... my friend had something similar and it was the gear selector since she has auto trans...
check the gear, make sure the pedal is all the way.. simple things to bypass..
good luck..
Old Jul 24, 2011 | 07:01 PM
Vlad1024's Avatar
That confused me.
Sounds like a relay, probably the accessory relay. Or some bad wires going to the ignition switch. Or the ignition switch.
Old Jul 26, 2011 | 02:59 AM
frogbox's Avatar
my 2006 toyota scion xa won't start at all. I tired jumping it and it didn't work. So we charged the battery and then tired it again and it still won't start. The head lights come on and that's all. So I don't know why it won't start. Dose anyone have an idea of what might be wrong with it and why it won't start
Look into changing your fusible link , $35 part from dealer.
Old Feb 13, 2019 | 05:19 PM
Williamgd2's Avatar
Default Check your grounds
I just fixed my 2012 xB that wouldn't start about 10% of the time. I would hookup my jump box and without adding power from the jump box and the car would start. I ran another ground from the neg battery terminal to the starter mounting bolt and it starts really quick every time.
I would check out your grounds and if you run a new ground wire like I did ! Don't share your new ground wire with any existing grounds, that's why I went to the starter. Good luck@
__________
etpascual86
May 6, 2013 08:31 PM
kmrort
Dec 19, 2012 12:08 AM
Xx AzN xX
9
May 13, 2011 12:54 AM
idriveatC
Jan 17, 2009 09:25 AM
bdballer69
Dec 6, 2004 12:11 AM
